Help with nfusion phoenix suns disconnected
Username: Daneegha
Post Number: 200
screen displays I-on N-on P-off Emul Off Suns disconnected,
Any help please. I tried to reboot stb and router and no luck.
Thanks!
Username: Plymouth
Post Number: 14271
barak obama
Do a factory default then rescan your satellites then do a hard reboot with back panel switch.
Username: Orbill
Post Number: 14
After a factory default, do you have to re install the files
Username: Plymouth
Post Number: 14272
Orbill
No!
Username: Daneegha
Post Number: 201
I tried that and nothing happened.
It still displays suns not connected.
Username: Plymouth
Post Number: 14273
Barak
Go in menu>System Settings>SW Version then give me the program Version!
Go in menu>User Settings, put the autoroll to "Dish" then the Emulator to "On"!
Power off the Modem, the Router and the receiver then power on in this order: Modem, Router and Receiver( wait 1 minute between each items).
Username: Daneegha
Post Number: 202
Boot: r3x 1.30 software ver: 1.54.2 ipvr 0.77 CDC checked.
I tried emul on and autoroll to dish,
from what I understand when emul is on only with stand alone. But with Iks it must be off, anyway I still no luck.
It shows I-On/n-on/p-on/emul-on/suns disconnected.
Thanks!
Username: Daneegha
Post Number: 203
I tried rebooting, modem, router and stb and still nothing, btw I forgot to mention I have power lines involved, and I tested the network with my laptop and I know is good.
Username: Plymouth
Post Number: 14274
Barak
Ok!
Now check it!
Menu>Internet: put those settings!
Network connection> On
Auto Update Check>Off
Network Information: on DHCP/Static, put DHCP
Proxy Connection>Off
Do a hard reboot!
If it not work!
Give me the info on Network information:
IP Adress??
Subnet Mask??
Gateway??
PVR Server IP Adress??
Username: Daneegha
Post Number: 204
I have to go to work, but I will give it a try in 4 more hrs,
Thanks!
Username: Daneegha
Post Number: 205
Hi, I'm back.
I reset to the settings above and now screen shows,
I-off/ N-on/ P-off/ Emul-on/ Suns Connected.
Still no picture.
Username: Daneegha
Post Number: 206
Thanks! Plymouth, it works perfect now after I change the settings and hard reboot it.
You are the Man!!!
Username: Plymouth
Post Number: 14278
barak obama
Happy to hear it!
You are welcome!
Username: Nydas
Post Number: 19131
Plymouth: Please do not join the White House if offered. Quebec and Canada needs you!
Username: Plymouth
Post Number: 14281
LOL!
Username: Pwilli
}I have a 15 year old 45 inch projection tv it's only been repaired once 6 years ago.repairman says the circuit board has gone bad. how much longer will this set last?
thank you p williams
Username: Plymouth
Post Number: 14284
PWilliams
First you posted in bad forum!
The good forum is this one: https://www.ecoustics.com/electronics/forum/home-video/15131.html
From what I know the reliability depends of the brand of your TV, the Sony will not last too much longer than 6 years because the tube are very bad in comparison with a RCA rear projector!
List the brand and model of your TV, it will help us to talk about your problem!
Username: Jayman1
Post Number: 13
hi
how to load new file on nfusion solaris . please help
Username: Jayman1
Post Number: 14
how to load new file for nfusion solaris?
thanks
Username: Plymouth
Post Number: 14364
jayman1
With null cable(serial port)!
