Babyboy163 its from serial here.post the numbers/letters from below the main barcode something like 7700xxxxxxtt123 or 8200xxxxxQ123 Or the security code like Q123 can be found in a small box then i can help you
they are too small holes each side of the radio put a very small screwdrive or long nails or coat hanger into the hole and push outwards sideways. and carefully pull the radio forward. hope this helps. ps. the small box is on the label/sticker. if your not sure upload photo of the labels/stickers from radio.
Hi! I have problem with stereo code, witch i don't have My car is: Audi A6 Avant '97 and stereo is Blaupunkt Delta CC Numbers, that i found in stereo was WDCS-BL-7644894380 AUZ1Z4V8789485
Can You help me with the code? I'm so tired to hear only my broken exhaustpipe noise :D
Posted on Tuesday, May 04, 2010 - 07:37 am: Hi! I have problem with stereo code, witch i don't have My car is: Audi A6 Avant '97 and stereo is Blaupunkt Delta CC Numbers, that i found in stereo was WDCS-BL-7644894380 AUZ1Z4V8789485 =====================================
Sorry...this code will only be available from your AUDI Main Dealer or using a Radio Decoding Service
ok no problem i was given this cd player from a friend for my transit pick up as i only have a cassette in there at minute just thought i would ask for your help i will just have to pay for the code now thanx for your time
regards dan
RE first post hi im looking for a code for a ford 6000 RDS E.O.N
serial no M013035
part no XS6F-18C15-AA
also has numbers E11 in a circle then 10 R- 02 0025 then V.C.A then e11 in a square then 020025
Audi A4 B5 1.8t quattro. Concert I radio. I just finished rebuilding the engine, got about 3 grand into the car. Great car. Just need good tunes to cruise to. Here is the serial and other information if you could please lend a hand.
"SERIAL NO. 30392"
Barcode: AUZ5Z6V0028661 OR (Zero's or O's) AUZ5Z6VOO8661
Posted on Saturday, May 15, 2010 - 02:02 pm: Audi A4 B5 1.8t quattro. Concert I radio. I just finished rebuilding the engine, got about 3 grand into the car. Great car. Just need good tunes to cruise to. Here is the serial and other information if you could please lend a hand.
"SERIAL NO. 30392"
Barcode: AUZ5Z6V0028661 OR (Zero's or O's) AUZ5Z6VOO8661 ==============================================
Sorry...Main AUDI Dealer or a Radio Decoding Service only for this code
Posted on Saturday, May 22, 2010 - 11:52 am: Hi looking for a code for my G/f's Renault Clio Model no 22dc279/62f serial No 8200029541 TL088 can any one please help and stop my earache ----------------------------------------------------------
Andrew83 Please note that code entry is only possible when "CODE" is shown in the display. If the display continually shows four bars " - - - - " then the unit may be codelocked and will need to be left switched on for up to two hours to reset before another code entry attempt is possible. If it does not reset after this time, then all of your code entry attempts may have been used up, and the unit will need to be sent to be decoded and reset.
Code Entry as Follows:
Switch Radio On - Display Shows " CODE " Then " 0000 " Press preset " 1 " repeatedly for 1st Digit Press preset " 2 " repeatedly for 2nd Digit Press preset " 3 " repeatedly for 3rd Digit Press preset " 4 " repeatedly for 4th Digit If the correct code number is now shown Press preset " 6 " to Enter
Hello everyone! I am here for the same reason as all of us. I have recently bought a Renault Megane Scenic and had to remove the battery. After putting the battery back in, no radio, because I do not have the code... :-((
It is a Philips radio, details as follows: Serial number: RN449FW4129000 Model number: 22DC449/62L Prod. number: FD0798104129000
Thank you very much in advance for all the help! sogor
Posted on Tuesday, May 25, 2010 - 12:51 pm: Hello everyone! I am here for the same reason as all of us. I have recently bought a Renault Megane Scenic and had to remove the battery. After putting the battery back in, no radio, because I do not have the code... :-((
You are the man! I have just tried it. I had a little trouble putting the given numbers into the memory, but after having searched how to do that, it worked, no problems! I have got the radio back on in my car again! Thanks again, I really appreciate it!
You are the man! I have just tried it. I had a little trouble putting the given numbers into the memory, but after a quick search how to do that, it worked, no problems! I have got the radio back on in my car again! Thanks again, I really appreciate it!
New battery...need radio code for my 2006 VW Passat. Radio S/N: VWZ1Z7E5316721. VIN: WVWEK73C66P060007. Locked system with wrong code...leave ignition on 1 hour...then enter code??? HELP!
Posted on Thursday, May 27, 2010 - 01:28 pm: New battery...need radio code for my 2006 VW Passat. Radio S/N: VWZ1Z7E5316721. VIN: WVWEK73C66P060007. Locked system with wrong code...leave ignition on 1 hour...then enter code??? HELP!
Sorry...Main VW Dealer or a Radio Decoding Service only for this code
PayPal donations to my Code Calculator Software Fund are always most welcome Donate link here: http://www.paypal.co.u payments to: codehelp@hotmail.co.uk
Thanks, the code worked!! That is amazing !!! Cheers!!! Yeaaaah music again !! Many thanks once again!!! I wish to everyone on the forum.... Happy Holidays from Greece!!!
Hi, I've got a 1993 Honda Prelude Si radio that needs a radio code. model # : 39100-SV2-A000 Ref # : CQ-LH1412Z Serial # : 93G887220 Label # : M2C414004
Matsushita made the radio I beleive. Anyways if you could please look up the code and send it to my e-mail below. caseyer18@hotmail.com
Thank you very much. I would really appreciate this because this has caused me quite a headache.... and if I don't get the code I may get a worse headache from banging my head up against a wall from annoyance and the frustration this has caused me. There is no way in hell I am paying more than $20.00 to look up a damn code. Sorry! Anyways I would really appreciate your help. Thanks again.
hi i need a code for my blaupunkt radio in my citroen zantia. All the numbers on the barcode are... BP2775V9731623 7 642 775 394 96 133 457 80 thanks in advance
The only Honda radio codes that are available to be calculated for free from anywhere on the Internet will be radios made by
BLAUPUNKT. These will have a Serial Number beginning with BP and another number beginning with 7 *** *** *** found on a label on the radio casing
UNFORTUNATELY ... NO OTHERS !
So you will be wasting your time posting code requests here for any other make.
BLAUPUNKTS ONLY with a BP Serial Number
For EVERY other HONDA radio made by one of the other manufacturers then visit the website below
https://radio-navicode.honda.com
If they cannot provide your code then you will have to try your HONDA Main Dealer or a Decode Service who will plug it into a laptop and electronically read/recode the memory chip (EEPROM)
Hi am trying to get a code for a rover radio cassette the number stamped into it is RG949FV1116855 is this the number required? thanks in advance if you can help
Hi Guys, Hope someone can help me with the code for my radio. I've aRover and the stupid mechanic took out the battery just to change a bulb from my head lights. So my radio was made by Philips in France. Model no: 22 DC 594/60S Prod no: FD 0597068066828 Beside the radio has 14 numbers that maybe is the SN: RG594FV8066828 Thanks in advance!
Thanks hay88, it worked great but changer was a piece of junk. Putting old one back but see that I am missing the detachable piece of the radiopass card.Can I ask for assistance once more before heading to Paypal?
Hello everyone. Excuse my English not good, I'm Italian. I found this wonderful forum and I hope you can help me. I am looking for code for my radio cd Blaupunkt Fiat 169 CD
815BP532268121836
7 645 322 316
I hope not to have broken some rules of the forum, thanks in advance. Ciao Fiore
Posted on Sunday, June 13, 2010 - 05:03 pm: Hello everyone. Excuse my English not good, I'm Italian. I found this wonderful forum and I hope you can help me. I am looking for code for my radio cd Blaupunkt Fiat 169 CD
Hello everyone! I am back again. The CD player from my mates "S" reg Citroen Saxo has been nicked. He`s got the original one, but does not know the code. The numbers on the radio: GR0947W1628405 REF CITROEN 96 232 272 80 DAD CITROEN <<>> 9.18303 G.HF 62-00 02 00947 0330 162840 5 Could anyone help, please? Thank you! sogor
Good day I want to ask you about cod sat Radio 6010 Model no: 22DC461/62E 90 22 22214616 FD 10 99 15 2223 115 7700 433 074 U902 Gravage Code: 2223 115 Thank you
Sorry to trouble you again all, but this is quite important. Is it that the code is unavailable for that radio or just nobody wants to help because this is the second code I requested? Could anyone let me know please so I can take a step from there??? Thanks: Sogor
Hi...I have a BMW z3 and have never been able to use the radio..It is a BMW Business cd and the code we got from the dealer does not work? the s/n is BP 027329969013..Any chance you could help us...
Posted on Saturday, June 26, 2010 - 10:09 pm: Hi...I have a BMW z3 and have never been able to use the radio..It is a BMW Business cd and the code we got from the dealer does not work? the s/n is BP 027329969013..Any chance you could help us... ================================================
try emailing
restoredclassic@aol.com
as these Z3 radios can be either 4 or 5 digit codes
Please do NOT post the SAME request in more than ONE thread.
HONDA RADIOS.................IMPORTANT NOTICE
PLEASE READ BEFORE POSTING ANY CODE REQUEST
============================================= If you CANNOT find a code written on the radio or on a card in the glovebox (or similar "hidden" place ) then please read on
Please note:
The majority of HONDA codes are NOT readily available as access is required to the original factory database which is not commercially available to buy
HONDA radios are made by the following manufacturers
