Nova problems
Username: Frobi
Post Number: 502
After downloading Boot_V126 , then 114, the receiver does not turn on. Red light comes on but no display. Remote also does not work. Any ideas?
Username: Dwop_diablo_rojo
According to those that know such things, here is the info needed to successfully load the Nova114 file that is being discussed above ...
Step 1 - Load u17 factory as main to clean the Unit out.
Step 2 - Then load the boot 126 file as boot
Step 3 - Then load u27 factory as main
Step 4 - Then load the ver 114 file as main
then do a factory reset and rescan
Username: Frobi
Post Number: 503
Thanks.
I tried all that but,
I get all sub menus but do not get "factory reset" on the menu, so I am stuck.
Username: Lroy
Post Number: 527
Dwop Diablo Rojo, is the nova really working with boot 126 and 144 file as per your instructions?
yes . limited channels freezing.
Username: Lroy
Post Number: 529
Did tested the files 126 and 114, got limited channels, no freezing but some amount of rebooting. Don't really like it.
