Where to get Rd Audio in georgia?
Username: Jemone
Tucker, Georgia United States
Post Number: 344
I am in need of a new subwoofer amplifier.
Username: Gcs8
Atlanta, Ga
Post Number: 650
i think the main office was based in tucker or by gwinnett place mall.
are you set on an RD amp?
Username: Jemone
Post Number: 345
not necessarily, i just think i want better quality than hifonics this time.
Username: Gcs8
Atlanta, Ga
Post Number: 653
sundown, AQ, some one else will chime in with something else but those are both great amps that will put out more then what they say they will.
how many watts do you need?
Username: Jemone
Post Number: 346
I am probably going to require about a 2000 watt sub woofer amp.
Username: Gcs8
Atlanta, Ga
Post Number: 654
at 2 ohms or 1 ohm?
Username: Jemone
Post Number: 348
1 ohm. I am finally going to buy a Fi btl.
Username: Gcs8
Atlanta, Ga
Post Number: 655
http://www.sundownaudio.com/index.php/products/discontinued/saz-2000d.html
http://www.audioque.com/aq/?page_id=28
those would be my picks.
Username: Gcs8
Atlanta, Ga
Post Number: 656
or get in on the pre order for the saz-2500 http://www.soundsolutionsaudio.com/forum/SAZ-2500D-Pre-Sale-OPEN-t38593.html it goes on tell July 4th i think. that would be a perfect match to give you just a little head room or to add some options on the BTL.
Username: Gcs8
Atlanta, Ga
Post Number: 657
also the pre-sale is still open and supposedly the amps are ahead of seclude so you would get it rather soon if you are willing to wait but you get a discount ^_^.
Username: Jemone
Post Number: 349
All of the options you suggested looked quite beastly. Thanx
Username: Gcs8
Atlanta, Ga
Post Number: 658
any time glad i could help, hope you have some good electrical.
Username: Bonhamd
Traverse City, MI
Post Number: 2228
also check out the cresendo 3KWP - 3K plus for $550 brand new, 2 year warranty
Username: Gcs8
Atlanta, Ga
Post Number: 661
also a good choice if you beef up your BTL for more power handling, you are going to need some good electrical for this set up on 3k watts tho.
Username: Jemone
Post Number: 350
That crescendo looks like ALOT of amp. I should have gotten a bigger alt.LOL Oh well, time to buy a battery bank. HEH hE he
Username: Gcs8
Atlanta, Ga
Post Number: 663
depending on how much your alt was or how much the upgrade is for your car after 2 or 3 battery's you are probably at the same cost, as far as i remember its better to keep your voltage up then big battery bank. i reserve the right to be wrong, some one else will chime in and tell you. but if you have ~200 amp alt cram in 2 or 3 battery's total and you should be good to go.
don't forget to post a build log when you get every thing.
Username: Jemone
Post Number: 351
I have the big three done, I have a 220 amp alternator waiting for install.What type of battery setup would I need to run that sweet sweet Crescendo....mmmmmmm... crescendo... ahhhhhhh.LOl
Username: Jemone
Post Number: 352
You answered before i could ask! LOL
Username: Gcs8
Atlanta, Ga
Post Number: 665
hahahha, uhmm i would say that alt + batt under the hood and one in the back, biggest one you can fit under the hood and eather a matching one or a bigger one in the back and depending on your wire eather 1 or 2 runs of 1/0 ga for both pos and neg from the front battery will do you a lot better then your car as a ground the welds in your car are only ~ 4ga wire. whats your budget?
Username: Gcs8
Atlanta, Ga
Post Number: 666
so like one run of http://www.knukonceptz.com/productDetail.cfm?prodID=KFX0BK-50 witch will handle 375 amps at 20' or two runs of http://www.vertexaudio.com/store/pc/Shok-Industries-Reference-CCA-1-0-Red-50-Spo ol-62p178.htm that will handle ~260 amps for the same run.
Username: Jemone
Post Number: 354
My budget is.......getting out of control! LOL I told my wife I was going to spend no more that $1200, she is just going to have to be mad for a little while. It is looking more like $1600-2000. Look at me being all big and bold while she is safely away......wait , I think I heard her car pull up.....no it was the neighbor.... like I said I am a man and spend what I want. LOL
Username: Insearchofbass
2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ
Post Number: 14381
yeah who needs one of the new rd amps phoowy
Username: Gcs8
Atlanta, Ga
Post Number: 668
hahahahahhahaha, my girl just bought me my 15" FI Q loaded as well. i
should have a build log coming soon.
well how much of your budget is free as of right now i should say, then we will go from there you may want to make a parts list and add every thing up. we will help you the best we can.
Username: Gcs8
Atlanta, Ga
Post Number: 670
lol @ sean
Username: Jemone
Post Number: 355
Yeah, I have mad shopping to do now. I will keep you all posted. As for the budget not sure yet how much is left. How come none of my hobbies are cheap? Between drawing and sound. I stay quite broke. hA HA he
Post Number: 14386
as you can tell i dont like the new rd amps
Username: Jemone
Post Number: 356
You guys are bad, expensive yet highly persuasive influences. LOL
Username: Deadrabit
Marionville, MO
Post Number: 2454
i know a guy that is selling aq2200s for 275.. or maybe 300 now. i think he has two left.
Username: Gcs8
Atlanta, Ga
Post Number: 672
you think you have it bad, my hobbies are car audio and computers. i am pretty sure my computer cost me more than my whole car's set up, or close to the same.
Username: Gcs8
Atlanta, Ga
Post Number: 673
by the way i think you live pretty close might haft to meat up some time.
Username: Jemone
Post Number: 357
Heck of a deal, are they new, or gently used.
Username: Gcs8
Atlanta, Ga
Post Number: 676
that is a hellof a deal, all ready have my saz-3000D tho
