Cd player doesnt ask for code
Username: Shifu
i pulled out the main cable plug from behind the cd player to fit on some additional speakers wires. At this stage i only checked the wire colours on the cable plug but did not fit the speaker wires.. i reinserted the cable plug back in to the cd player, (and checked to see its in properly) but now the cd player display remains blank.. i've checked the fuse and there is power going in to the unit, the cd ejects and loads and the lights come on but the cd player does not switch on or play and there is no request for Security CODE (which i have)
the cd player/ radio unit is for the 2003 model and its the default CD player that comes with the car.. i also disconnected the battery and put it back in still no luck
Username: Illuminator
Post Number: 5450
What kind of car is this? If it's a factory head unit, it doesn't matter anyway...nobody is going to steal it. And if they do, what good is a code to you anyway?
Username: Shifu
erm i dont think you read what i wrote.... my CD PLAYER does NOT work nor DOES it ask for a code.. and yes it does matter if the unit doesnt play how do i operated it?
Post Number: 5451
It was hard to understand with how you worded it.
This goes in the codes forum:
https://www.ecoustics.com/electronics/forum/car-audio/632215.html
Make sure you mention the serial number and model number of the stereo as well as what car it is. Just vaguely saying you have a head unit that doesn't ask for a code will not get you the answer you need.
