Bronze Member Username: Bobby3342Post Number: 54 Registered: Mar-10 | going in a dodge intrepid 2000 right now i have 2 already in a box that i made so shoul i just make a single box and add the third sub in the back trunk or should i make abox for all 3. heres my idea 38 or 39 for the length and 13.5 maybe 14 for Height 28 deep and i was going to have the port in the back of box? i want good numbers on the mic but i also am after those low frequencys, im looking to run 2000 rms total for everthing in my car. right now i have an audioque 1200d and 3 re se12d4s should i get another amp and go with 3 amp setup(1for 6.5 comps)2 for subs) or buy another amp for subs and go with 2 amp setup total |
Silver Member Username: 420pimp2Baltimore Atlantic Ci..., MD, NJ Post Number: 952 Registered: Jan-06 | bump |
Gold Member Username: Dustin3Box Designer & Builder...Dustin Post Number: 5666 Registered: Oct-05 | I can do it for you. |
Platinum Member Username: Insearchofbass2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ Post Number: 14375 Registered: Jun-04 | yeah bassman3 is your go to guy |
Bronze Member Username: Bobby3342Post Number: 65 Registered: Mar-10 | ok so whats the deal bassman? |
Gold Member Username: Kyle_lowePost Number: 1168 Registered: Apr-06 | i just going to guess that your se's are d4 since you had two of them on an aq1200. so if you were to run all three off a single amp you would probably need something like an aq 3500d because the final impedance would be 2.66 ohm. |
Gold Member Username: Dustin3Box Designer & Builder...Dustin Post Number: 5667 Registered: Oct-05 | Just shoot me an email and i'll get you it to you for $10 and it comes with a cut-list which shows you every cut that needs to be made. Send me an email at DLaudiotech@gmail.com |
Silver Member Username: JemoneTucker, Georgia United States Post Number: 353 Registered: Jan-06 | I get so tired of Bassman3 thinking he knows every thing about boxes. I too build boxes, sure they are made mostly of cardboard, duct tape and tears, but they are boxes none the less, so there. LOL |
Gold Member Username: Dustin3Box Designer & Builder...Dustin Post Number: 5668 Registered: Oct-05 | lol, i try to help as much as I can. People don't know all my boxes are made out of cardboard too... shhhh... ;) haha Just playin, of course. |
Bronze Member Username: Bobby3342Post Number: 66 Registered: Mar-10 | yup they are dual 4s i talked to dj he said i could run a 2200 at .6667 and the amp would never see that load i dunno the reason i got the third sub was cuz i wanted to hit the mic better do ya think if i switch to the aq sdc2.5 12s that i would get more output than 3 12 re se s i hear people are getting good numbers with the sdc2,5s i like my se 12s but 86.1 for sensitivity is not good hmm what to do |
Silver Member Username: CwruckPost Number: 313 Registered: Feb-10 | the aq's will more than likely get louder, but the re's will sound much cleaner. also 12s normally don't have high sensitivity, you start getting higher with 15s and 18s especially |
Bronze Member Username: Bobby3342Post Number: 67 Registered: Mar-10 | cwruck ya think i should get the sdc 2.5s or stay with 3 12 re se s |
Silver Member Username: CwruckPost Number: 314 Registered: Feb-10 | well what do you want exactly? do you know your freqencies well? those aq's are going to struggle below 40 hz compared to the re's but will be louder 40-60. the re's will have good response from 20-60 depending on tuning, but much more range than the aq's. if you feel you dont listen to much music with low low bass and want to be loud, i say the aq's. if you want cleaner sounding bass i say the re's both set ups will be very loud, just depends what you want really. |
Bronze Member Username: Bobby3342Post Number: 68 Registered: Mar-10 | damn i am after the low frequecys and i listen to rap and jazz and everything i think i prolly should stick with the re s did you own the sdc 2.5s? you seem to know ur stuff |
Silver Member Username: Boston_splHighland, CA United States Post Number: 224 Registered: Nov-08 | If you really want sum serious SPL I'd recommend two of these babies and hold on! http://www.sonicelectronix.com/item_13227_JL+Audio+6W3V3-4.html |
Bronze Member Username: Bobby3342Post Number: 69 Registered: Mar-10 | your fkin nice dude jl 6.5s my 10 month olds butt moves more air than those and shes a girl good jk though |
Silver Member Username: Boston_splHighland, CA United States Post Number: 226 Registered: Nov-08 | LoL! True that. |
Gold Member Username: Kyle_lowePost Number: 1169 Registered: Apr-06 | bobby you could run the aq 2200 at .667 but remember that it will not be under warranty if you do. |
