Getting first system, suggestions?
Username: Jayg
I'm trying to get different opinions before I buy everything. I was orginally to get dual Kicker comp 10's but everybody said they were crap. I don't need anything with thunderous bass but something clean and good but I need it to fit my budget.
Here is a recommended setup I got:
Sub:
http://www.woofersetc.com/p3415/RWE302--MB-Quart-12"-1000-Watt-Reference-Se ries-Subwoofer.htm
Box:
http://176719.brightwebsite.com/store-products-31072-Ground-Shaker-ESQ112-12-Sin gle-Sealed-Standard-Square-Box_41351482.html
Amp:
http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/6635939/vpcsid/0 /SFV/30046
My budget is like $320 and thats including a stereo. Could I substitute that amp for this: http://cgi.ebay.com/HIFONICS-HFi-HFI100-4-800W-4-CHANNEL-AMPLIFIER-AMP-KIT-/3503 34316903?cmd=ViewItem&pt=Car_Amplifiers&hash=item51918d7167
And any other recommendations?
Username: Gcs8
Atlanta, Ga
Post Number: 609
don't cheep out and set your car on fire. also a 4 channel amp does not a sub amp make. find a nice class D amp for the sub.
Username: Jayg
Someone suggested that amp because they said if I wanted to add 4 comp speakers later it would power my whole system. Any good priced brands you would recommend. I'm trying to keep sub+box+amp around $260-$275
Username: Skdooley
Roanoke, VA Usa
Post Number: 865
Save up some money and do it right the first time. If you rush it and get whatever you can you're not going to be satisfied. If you're serious about wanting some decent car audio, its going to cost a little money.
Username: Jayg
Well are these Rockfords good to go with? http://cgi.ebay.com/Rockford-Fosgate-R1L-2X10-Dual-10-600-Watt-Enclosure-/190403 032772?cmd=ViewItem&pt=Car_Subwoofers_Enclosures&hash=item2c54e7b6c4
It fits my price range and seems decent.
With this amp: http://cgi.ebay.com/HIFONICS-HFI100-2-400W-RMS-2-CHANNEL-AMPLIFIER-AMP-KIT-/3901 99056841?cmd=ViewItem&pt=Car_Amplifiers&hash=item5ad9ad19c9
Username: Nd4spd18
Philadelphia, PA
Post Number: 11161
Get away from the hifonics amps, they do not do rated power and are poor quality.
More on that
https://www.ecoustics.com/electronics/forum/car-audio/542894.html
Diamond Member
Www.stainles... .ecrater.com
Post Number: 22947
$320? For everything? Not gonna happen with something you'll enjoy. Most pay that or more for each component. Take a step back and think if you want it right or just right now.
Username: Cwruck
Post Number: 284
the thing about 4 channel amps is that you cannot use them to power subs, and to power speakers at the same time, you could however use the front 2 channels to power speakers and use the rear channels and bridge them to power 1 subwoofer, but its more than likely not enough power and not very efficient.
basically you get what you pay for. at least to an extent. there are many non mainstream companies that offer products that will outperform mainstream companies in quality performance, and best of all price
your best bet if you can't stretch your budget is too learn about products, what is good and whats not and look on craigslist, every now and then people sell great stuff for cheap because they are hurting for money and its much easier for them to sell locally than deal with ebay
Username: Cwruck
Post Number: 285
sorry i noticed you only wanted 1 sub and a 4 channel could work for that, like how i said above. but you would be better off buying 1 set of speakers, you only need 1.. power those with a 2 channel amp, and then use a subwoofer and power it with a class d amp, you will have more power for bass, with much better wiring options with the sub, and not kill your electrical.
i have a great eclipse 2 channel amp i am looking to sell in the near future, it will blow those other amps out of the water performance wise and it would be cheaper as well
Username: Boston_spl
Highland, CA United States
Post Number: 179
^X2 (Paul)
Username: Rosrock
Michigan
Post Number: 376
i reccomend you get this 12" or the hardtimes pro he has on there to.. he gave me it for 160 shipped.. shoulda been 250+ lol
http://cgi.ebay.com/12D2-165-Orion-HCCA-custom-clone-Robot-Underground-/22062251 0659?cmd=ViewItem&pt=Car_Subwoofers_Enclosures&hash=item335e205a43
im sure if you talk to him hell lower it down to 180 shipped... i dont see why not since he gave me the hardtimes pro for 160 shipped!
Post Number: 191
That listing has been removed. Just FYI.
Username: Rovin
1 15 = 153 DBs ...Trinidad & T...
Post Number: 16400
hmmm for $320 u might get used or low grade new stuff
go on ebay & check out powerbass asa series of speakers\amps\subs - u might be able to squeeze out a system with that low budget ....
