Okay I have a kicker zx2500.1 mono. I have two 12" L7's and two 15" L7 all four Omh's. I need to know how I can wire all four up to this amp to get the most from the amp. Is it possible to wire them down to a two Omh. Any comments and suggestions and most of all help would be appreciated. Thank you
I agree with Glasswolf but, if you insist on doing this then yes you can get all 4 down to a 2 ohm load. Just wire all 4 subs individually in series then run them parallel to each other down to the amp.
