Silver Member Username: Mash4kash
Lafayette,
LA
Post Number: 308 Registered: Feb-06
Posted on what ohm load will 2 kicker comp vt 2 ohm svc subs drop to in parallel and in series?? The 12volt.com does not show it in 2 ohm svc. |
Gold Member Username: Southernrebel
Monroe,
Louisiana
Team Audible...
Post Number: 8070 Registered: Mar-04
Posted on 2 SVC 2ohm subs in parallel will give you a 1ohm load. |
Platinum Member Username: Nd4spd18
Philadelphia,
PA
Post Number: 11115 Registered: Jul-06
Posted on 1 ohm in parallel, 4 ohm in series |
