The only Honda radio codes that are available to be calculated for free from anywhere on the Internet will be radios made by
BLAUPUNKT. These will have a Serial Number beginning with BP and another number beginning with 7 *** *** *** found on a label on the radio casing
UNFORTUNATELY ... NO OTHERS !
So you will be wasting your time posting code requests here for any other make.
BLAUPUNKTS ONLY with a BP Serial Number
For EVERY other HONDA radio made by one of the other manufacturers then visit the website below
https://radio-navicode.honda.com
If they cannot provide your code then you will have to try your HONDA Main Dealer or a Decode Service who will plug it into a laptop and electronically read/recode the memory chip (EEPROM)
