New member Username: Lapidus20
Post Number: 1 Registered: May-10
Posted on hi who can help me to get my car radio codes . thanks |
Silver Member Username: Hay88
Post Number: 876 Registered: Mar-10
Posted on Lapidus20 you need to post the info off of the radio model serial numbers and anything you find to see if we can help you. |
Post Number: 2 Registered: May-10
Posted on the radio a genuine vw radio as model 1999 and i don't know where to find de model serial numbers. thanks |
Post Number: 879 Registered: Mar-10
Posted on you need to remove the radio from the car to get all the infomation |
Post Number: 3 Registered: May-10
Posted on ok thanks |
Post Number: 4 Registered: May-10
Posted on hi i just remove my vw passat 1999 radio and i will like to get the codes VWZ1Z3W7995130 1J0035186 B 7648227060 THANKS |
Post Number: 5 Registered: May-10
Posted on radio is GAMMA model |
Post Number: 6 Registered: May-10
Post Number: 7 Registered: May-10
Posted on hi i just removed my vw passat 1999 radio and i will like to get the codes VWZ1Z3W7995130 1J0035186 B 7648227060 THANKS radio is GAMMA model |
Post Number: 8 Registered: May-10
Posted on there is someone who can help me please .? thanks |
Post Number: 9 Registered: May-10
Posted on hi hay88 i just removed my vw passat 1999 radio and i will like to get the codes VWZ1Z3W7995130 model no :1J0035186 B 7648227060 THANKS |
Post Number: 10 Registered: May-10
Posted on can you please help me the codes .many thanks to you all |
Gold Member Username: Regrooster
Post Number: 3969 Registered: Aug-08
Posted on You are wasting EVERYONE`s time with this multi-posted request. It has already been answered PLEASE do NOT MULTI- POST on this forum |
