Radio Code
Username: Shantelljames
I have a 1992 bmw 325is and I need a code for my stereo. The serial number on the radio is F10822851A can I get any help please....
Thank you
Shantell
Username: Regrooster
Post Number: 3810
Sorry ...not in my database
Try emailing
restoredclassic@aol.com
to see if they can help
Mention this forum
Username: Joe_123
hiya, iv got an 1997 renault megane with a philips radio, the battery was changed recently and the radio now needs a code. looked all over the car and through the books but no sign. could you help pls
- model no. 22DC593/62L
- Production no. FD 0597244180410
the etched number on the side is RN593FV4180410
Hey for fyi I called the bmw dealership and they gave me the code for free over the phone....Add this one to your data base
Serial# F10828851A code is 43166
Tahnks for your help...
Post Number: 3825
joe
Username: Joe_123
Posted on Tuesday, May 11, 2010 - 02:38 pm:
Try emailing
Mention this forum
Post Number: 3826
shantell
Posted on Tuesday, May 11, 2010 - 02:39 pm:
Thanks for that.
Your dealer has access to the original factory database ...which is not commercially available.
You were lucky to get your code...and for for free.as well !
I ran your Serial Number through the available calculators and none came up with your working code 43166
Username: Bill336s
Hello everyone. Just found this site and hope someone can help.I've just bought 2 Blau. rad. cass. players. Coupled each one up for bench trial prior to fitting, one comes up with "CANCHECK", the other one with "CHECK". Fiat instruction book with CANCHECK unit which came from a Fiat Dublo says this should go after a few seconds, left it for 10 mins..... still there. The other unit is out of a Fiat Punto so I assume it's the same problem for both units.
Details as follows:- CANCHECK unit, Blau. BPO37135316945, also 7 640 371 316. Code in book 5121.
CHECK unit,Blau. BP137424830158. 7 641 374 316 Code unknown. Help with this too???
Reading through this site I note the great success with decodes, hope someone can help me resolve my problems. It's a BIG, BIG ask and I much appreciate any help you can give.
I posted this entry earlier today 11/05/2010, and it came up on screen but has since vanished.
Username: Hay88
Post Number: 769
hi Bill
BP137424830158 = 6252
If you are trying to fit this radio to a different vehicle, then you may find yourself with the Error message of "CANCHECK". As well as having a conventional Radio Security Code number, this stereo is also electronically paired, or "Married" to the engine management system of the vehicle it came out of using very sophisticated CAN-BUS system technology.
When it is first powered up, it will communicate with the vehicle, and a message of "WAIT" will appear on the display whilst this process is in operation. If communication has been successfull, it will prompt for the Code number to be entered in the normal way.
However, if removed and refitted into a different vehicle other than the original one, it will not recognise the encrypted CANBUS identification of the new car, and will instead display an error message of "CANCHECK".
This Radio cannot therefore be transferred from one car to another, unless it has first been reset back into its original "Delivery Mode" with the CAN-BUS data memory reprogrammed for use with the new vehicle.
Username: Bill336s
Hello Hay88. I had a sneaking suspicion that something like this might be the case. Sellers didn't mention anything so I've been caught napping.........twice. I suppose the re-programming is more expensive, indeed if available, than another radio as the host car is an old, 1992 Seat Ibiza built prior to modern "advance technology"
Many many thanks anyway, and if I have any future, similar, problems I'll know where to come. Cheers, Bill.
Username: Hay88
Post Number: 770
Full details of "CANCHECK" repair service can be found on this website: http://ice.dndservices.co.uk/search.php?mode=search&page=1
its about £17.50 up.
Username: Dtella
Hello,
I bought a VW bora 2001 from private sale, and seems radio has been locked, could some one pls help me find the code.
Serial number: W92ZSNE5GBC1.
Username: Dtella
Hello,
Serial number: W92ZSNE5GBC1. for GAMMA radio
Thanx
Post Number: 3904
dtella
Username: Dtella
Posted on Friday, May 21, 2010 - 05:29 am:
Hello,
DUPLICATE POSTING...Why post the SAME request in two different threads?
