New member Username: AgnesePost Number: 1 Registered: Apr-10 | I NEED A CODE FOR MY RADIO RENAULT MODEL NO 22DC277/62 RN277F40755968 PROD NO FD0804490755968 CAN ANYBODY HELP ME? |
Silver Member Username: Hay88Post Number: 416 Registered: Mar-10 | hi aga post the numbers/letters from below the main barcode something like 7700xxxxxxtt123 or the security code like Q123 can be found in a small box then i can help you |
New member Username: AgnesePost Number: 2 Registered: Apr-10 | hi you need something like 8200258141/-D o 0? I'm not sure |
New member Username: AgnesePost Number: 3 Registered: Apr-10 | I've got also 8200256141TV562 |
New member Username: AgnesePost Number: 4 Registered: Apr-10 | and V562 SECURITY |
Silver Member Username: Hay88Post Number: 443 Registered: Mar-10 | Agnese your code is 4493 |
New member Username: AgnesePost Number: 5 Registered: Apr-10 | thank you very very much;)) I want ask you another thing-you know how I can insert this code,because my radio still show me inscription -ERROR? |
Silver Member Username: Hay88Post Number: 445 Registered: Mar-10 | note the radio does not lockout after a wrong code entry it only doubles the time to wait before the next retry...if a wrong code is entered it will display error then after the delay should display "0000") IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY Turn on the radio and the display will show 'CODE' Use the steering controls for code entry. Press the [ ] button then rotate the thumb wheel for the correct first digit Press the [ ] button then rotate the thumb wheel for the correct second digit Press the [ ] button then rotate the thumb wheel for the correct third digit Press the [ ] button then rotate the thumb wheel for the correct fourth digit If the correct code is now shown on screen, press and hold the [ ] button for up to 10 seconds to store the code FOR NO STEERING CONTROL press the first preset button for the 1st digit, second button for the 2nd digit third button for 3rd digit forth button for 4th digit then press buttons 6 OR 5 to store. for 10 seconds |
New member Username: AgnesePost Number: 6 Registered: Apr-10 | YOU'RE GREAT!!;) thanks a lot,now my radio function very good;) |
New member Username: WangliPost Number: 9 Registered: Jan-10 | I would like to have so many visitors like you.How can you do that? Mothers Day Watches |
New member Username: JapanacPost Number: 3 Registered: May-10 | HELLO! PLEASE, HELP ME! Model/Make Renault Megane II Serial Number: RNRD7650052535 Barcode: 8200505114TB354 Security Number: B354 Product Number: FD0305510052535 I'D VERY APPRECIATE IT. |
Gold Member Username: RegroosterPost Number: 3861 Registered: Aug-08 | Hell2Hell New member Username: Japanac Post Number: 3 Registered: May-10 Posted on Sunday, May 16, 2010 - 08:21 am: HELLO! PLEASE, HELP ME! Model/Make Renault Megane II Serial Number: RNRD7650052535 Barcode: 8200505114TB354 Security Number: B354 Product Number: FD0305510052535 I'D VERY APPRECIATE IT. =========================================== Why post the SAME request in several threads? |
