Bronze Member Username: MatiPost Number: 71 Registered: Apr-08 | Mr,Doreen My notebook will not boot at startup. Windows Vista Home basic cannot find the boot record which results in a loop infinite. Please advise, Regards |
Gold Member Username: RunnerguyPluto Post Number: 2096 Registered: Sep-06 | If your fan is not working graphics card could be getting to hot before boot. Is your fan working? |
Platinum Member Username: PlymouthCanada Post Number: 13923 Registered: Jan-08 | Hi Yugene! Be sure that nothing are hooked in USB port or any port! Sometime if you hook a i-pod or somethink like this, the bios will not see your HDD! Go in Bios menu! Power the Laptop then press delete many time to access, check what is in the first boot! |
Gold Member Username: RunnerguyPluto Post Number: 2097 Registered: Sep-06 | do NOT listen to playmut he will only f@ck up yur pc![]() |
Bronze Member Username: MatiPost Number: 72 Registered: Apr-08 | Dear Sir, The fan is working properly, the usb connect is clear. Please advise Regards, Thank you |
Platinum Member Username: PlymouthCanada Post Number: 13924 Registered: Jan-08 | Yugene Are you able to enter in Safe Mode with F8? Check this link to Vista to enter in the Safe Mode:}http://www.bleepingcomputer.com/tutorials/tutorial61.html Try to return to a old restore date! You can also use your Boot disc or Vista disc to re-install Vista! |
Gold Member Username: RunnerguyPluto Post Number: 2098 Registered: Sep-06 | Check and see if you can get into your bios before you re-install |
Platinum Member Username: PlymouthCanada Post Number: 13925 Registered: Jan-08 | do NOT listen to zulu he will only f@ck up yur pc![]() |
Bronze Member Username: MatiPost Number: 73 Registered: Apr-08 | Dear Sir, Where can i own a startup cd of vista Home basic I don't have at he reinstalled vista cd. Thank you Regards, |
Platinum Member Username: PlymouthCanada Post Number: 13929 Registered: Jan-08 | Yugene You don't have a recovery disc with your laptop? |
Silver Member Username: FrobiPost Number: 496 Registered: Aug-06 | I hate Vista on my Toshiba laptop. I find XP is batter but hard to install on Toshiba due to drivers. |
