Need code for 98 honda accord radio
Username: Bozos_si
ok. so i bought a 98 accord and the code is on. i thought it was easy like the old ones but the honda dealer by us wants me to schedule an apt to get my code. they so call say they need to remove the radio but i believe i have the s/n number needed already. can someone please help me get the code i need? here is the serial number: M97A165995. if you need any more info let me know.
thanks.
bsolem_23@yahoo.com
Username: Bozos_si
vin: 1HGCG5552WA112085
Username: Regrooster
Post Number: 3809
HONDA RADIOS.................IMPORTANT NOTICE
PLEASE READ BEFORE POSTING ANY CODE REQUEST
If you CANNOT find a code written on the radio or on a card in the glovebox (or similar "hidden" place ) then please read on
Please note:
The majority of HONDA codes are NOT readily available as access is required to the original factory database which is not commercially available to buy
HONDA radios are made by the following manufacturers
ALPINE
AUTOSOUND
BLAUPUNKT
CLARION
KENWOOD
MATSUSHITA
PIONEER
The only Honda radio codes that are available to be calculated for free from anywhere on the Internet will be radios made by
BLAUPUNKT.
These will have a Serial Number beginning with BP and another number beginning with 7 *** *** *** found on a label on the radio casing
UNFORTUNATELY ... NO OTHERS !
So you will be wasting your time posting code requests here for any other make.
BLAUPUNKTS ONLY with a BP Serial Number
For EVERY other HONDA radio made by one of the other manufacturers then visit the website below
https://radio-navicode.honda.com
If they cannot provide your code then you will have to try your HONDA Main Dealer or a Decode Service who will plug it into a laptop and electronically read/recode the memory chip (EEPROM)
