Radio Code for 1998 Philips Radio Cassette Player
Username: Blue_peter
Dorking, Surrey UK
I have a 1998 Renault Clio RT
Registered 5/8/1998
The battery was replaced.
The original radio is a Renault Philips Cassette Players Auto Reverse
The radio is fully fixed in - so I cannot get to it to find out the Code
Can anyone help?
Blue Peter
Username: Regrooster
Post Number: 3789
It has to be removed from the dashboard.
Here is a video showing how to remove a standard radio from the dashboard.
A pair of extractors are required (available from Ebay , etc ) but these can be made from 2 pieces of bent, wire coat-hanger or 4 small drills(using the blunt end) or 4 small Allen Keys or 4 small screwdrivers or 4 nails or even 4 darts.
An assistant is useful to pull the radio out whilst you are releasing the 4
securing clips
http://www.youtube.com/watch?v=urC-4NbXvDQ
note: on some radios , these 4 holes are protected by 4 small screws. These can be unscrewed using the appropriate size of Allen key.
