Literally just bought a Megane for my daughter but the radio doesn't work, needs a code. Have 1617 but that doesn't work.. Serial No RN599FT4066591 and other No is 7700413537--B. Help.....Pleeaase Brian
G0dah If still not working upload photo of label/sticker O310 = 1617 AND Q310 =9611 IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY
Turn on the radio and the display will show 'CODE' Use the steering controls for code entry. Press the [ ] button then rotate the thumb wheel for the correct first digit Press the [ ] button then rotate the thumb wheel for the correct second digit Press the [ ] button then rotate the thumb wheel for the correct third digit Press the [ ] button then rotate the thumb wheel for the correct fourth digit If the correct code is now shown on screen, press and hold the [ ] button for up to 10 seconds to store the code
