Please need renault radio code
Username: Kirk29
Bangor, Down N.ireland
Hello if anyone could help me please i have just bought a renult van tonight for work am away driving all weekend and my radio will not work keeps asking me for a code have tried a few codes but to no luck so came to try my luck on this forum as dont want to be driving 2 days with no radio, The details of the radio is model number 22dc259/63 product number fd0602200266 i think this is the seriel number rn259f20266004 If anybody could help would be great help thanks allot kirk.
Username: Hay88
Post Number: 873
Kirk
hi post the numbers/letters from below the main barcode
something like 7700xxxxxxtt123 or 8200xxxxtt123 or
the security code like Q123 or T0U123
can be found in a small box then i can help you
Off of the radio
Username: Kirk29
Hi mate thanks for reply this is it
TOH 332
7700434436TH332
Hope that helps
Best Regards
kirk
Username: Hay88
Post Number: 874
Kirk29
your code is 4053
Username: Kirk29
Hi mate thanks very much will try it in the morning asap o you one cheers kirk.
