Wrong code for fiat panda blaupunkt radio?
Username: Jack2
one of the things i checked before i bought this 2004 fiat panda was that the radio code was written down in the service book.
however the battery got disconnected and the code i'd been left with doesnt work 0384.
for a start there doesnt seem to be a way of entering the digit 0 with keys 1 to 6- maybe another button is the shift key to get digits 7 to 0?
i'm sure its the wrong code-maybe someone can help with the correct code.
the radio is blaupunkt mod fiat 169cc and serial num 7 643 383 316 and the number on the barcode 5637016145
any help would be appreciated
thanks jack
Username: Hay88
Post Number: 661
Jack2 post the main bpxxxxyxxxxxxx and 7xxx xxx xxx off of the radio then i can help you. can be found stamped into metal casing.
Username: Jack2
Thanks for your help .
the nos are BP33830608512 and 7 643 383 316 . it'll be nice to have some sound in the car loud enough to drown out the wife nagging!
thanks
jk
Username: Hay88
Post Number: 674
Jack2
you can try 4212 but if still wrong please check BP33830608512 <
cause it still has a digit missing.i here for 10mins kk
Username: Hay88
Post Number: 676
Jack2
Username: Jack2
sorry you are right. i managed to write the numbers down incorrectly,
the num is BP 338330608512.
lucky for everyone i dont work in a bank i suppose
thanks
jack
Username: Hay88
Post Number: 678
jack 4212 is the right code for the given numbers
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE " then " - - - - "
Enter CODE in the order it is read - eg:
For Example, To Enter Code 1234
Press Preset 1 then 2 then 3 then 4
The Code will Enter Itself Automatically
Username: Jack2
thanks very much for that. i'll whack it in as soon as the timeout ends and let you know its ok
best
jack
Username: Jack2
thanks so much it worked like a charm.
best
jack
Username: Diana079
Post Number: 10
Hello!
Please give me a code to unlock my radio
Blaupunkt Car300 (D)
Serial: GM0300T5122970
7645 852 520
90 532 620
Made in Malaysia
Thank you very much!!!!!!!!!
Username: Diana079
Post Number: 11
Help me!
Username: Hay88
Post Number: 722
Diana079
try 5095
Username: Diana079
Post Number: 12
Hello!
7645 852 520
90 532 620
Made in Malaysia
Username: Hay88
Post Number: 728
Diana079
LOOK BACK UP TWO POSTS lol
Username: Diana079
Post Number: 13
Thank you !!
