I have a 1998 Renault Clio RT Registered 5/8/1998 The battery was replaced. The original radio is a Renault Philips Cassette Players Auto Reverse The radio is fully fixed in - so I cannot get to it to find out the Code Can anyone help? Blue Peter
Here is a video showing how to remove a standard radio from the dashboard. A pair of extractors are required (available from Ebay , etc ) but these can be made from 2 pieces of bent, wire coat-hanger or 4 small drills(using the blunt end) or 4 small Allen Keys or 4 small screwdrivers or 4 nails or even 4 darts.
An assistant is useful to pull the radio out whilst you are releasing the 4 securing clips
http://www.youtube.com/watch?v=urC-4NbXvDQ
note: on some radios , these 4 holes are protected by 4 small screws. These can be unscrewed using the appropriate size of Allen key.
