What Box Is Best?
Username: Mactasticlove
I have a 12' Punch P2 and i have both a bandpass box and a normal box which is smaller that i could put the 12' in. I dont know which would be better. My amp is only 450 watts, im new to the car audio. Pretty much learning as I go. Can anyone help?
Username: Glasswolf
Post Number: 13533
http://www.glasswolf.net/papers/boxtypes.html
pros and cons of most box types.
what i've gathered from that is with my 450 watt amp i need the ported box. If a 450 watt amp strong enough to push my Rockford Fosgate 12 P2?
Username: Skdooley
Roanoke, VA Usa
Post Number: 695
Look at what the P2 needs as far as RMS, and then look for an amp that will push that amount of RMS at the ohm load needed. You'll need to know what kind of voice coil(s) your sub is. As for the best type of box, a custom built one designed for the sub being played.
