Renault radio code
Username: G0dah
Literally just bought a Megane for my daughter but the radio doesn't work, needs a code. Have 1617 but that doesn't work..
Serial No RN599FT4066591 and other No is 7700413537--B.
Help.....Pleeaase
Brian
Username: G0dah
I have found the rest of the second number . The whole number is 77004135370310
Thanks
Brian
Username: Hay88
Post Number: 716
G0dah If still not working upload photo of label/sticker
O310 = 1617 AND Q310 =9611
IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ] button then rotate the thumb wheel for the correct first digit
Press the [ ] button then rotate the thumb wheel for the correct second digit
Press the [ ] button then rotate the thumb wheel for the correct third digit
Press the [ ] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ] button for up to 10 seconds to store the code
Username: Diana079
Post Number: 9
help mee please!!
Username: Hay88
Post Number: 723
answered other post
Username: G0dah
hay88, Code worked perfectly thank you very much. I now have a very happy daughter who can go to work siinging along to the music
