Amp help
Username: Gemmar26
I need to get a new amp but the problem is that i know nothing about them. All i know is that it has to support 2X1000w speakers! Any help would be appreciated! thanks
Username: Jan_b_vigne
Dallas, TX
Post Number: 14835
What brand and model speakers will you be using? What amp do you have now and why do you think you need a new amp?
Username: Gemmar26
I think i blew my last amp. well iturned the speakers up and the amp stopped working,
i have
cdplayer is aiwa xc-300
sony eon link system fm-am tuner ST-SE500
GenEXXA 10 band stereo graphic equalizer
And the speakers say QXF 15Vi Bass 400w RMS 1000w peak the size of the cone is 15".
thank you
Dallas, TX
Post Number: 14838
You don't know if you destroyed the amp?! What did you do to check whether the amp is working?
How high was the volume control set when the amp stopped working?
Username: Gemmar26
yeah the amp is dead. it hasnt worked since. i tried to get it repaired but they said it will cost around 90 so i thought i would get a new one. The volume was about 3/4 of the way to maximum.
Dallas, TX
Post Number: 14840
OK, if $90 is too much to pay for repairs, what's your budget for replacement?
