The power ratings say 15W RMS x 4.. Since I do not have an amp for my speakers yet, is this relatively low power? Also, the output voltage is 2V, does this mean I'll just have to adjust my amp gain for my subs to match?
Finally, if this unit is no good, does anyone have any suggestions for a similar head unit around the same price?
I'm sure it's a good headunit. Clarion makes good stuff, despite the 2V pre-outs etc. 15w RMS will be fine for your factory speakers. That's about what your OEM headunit puts out.
Link doesn't work, by the way, so I can't say anything more (especially regarding price and similar units)..
Built-in Bluetooth Rear USB NP400 Direct Connection 36 FM / 12 AM Front / Rear AUX Input LCD Monitor : 7-inch Built-In Bluetooth with built-in microphone (you can wirelessly connect your Bluetooth capable mobile phone to listen to calls through your car's audio system. HFP/OPP/A2DP/AVRCP protocols are supported.) MP3/WMA Compatible with ID3-TAG Display 36 FM /12 AM Station Presets Dolby Digital Rear USB Connector iPod Direct Control via USB (CCA723 or CCA748 iPod Cable Required for video) Rear AV Output Rear vision Camera RCA Input 24-bit D/A Converter Touch Panel Control 6ch/2 Volt RCA Output with subwoofer control 40 W × 4 Built-in Amplifier(16W RMS x 4 Channel) HD Radio Ready (with iTunes Tagging) (THD400 required) Navi Direct Connection (NP400 required) OEM Steering Wheel Remote Ready Sirius SSP Direct Connection Ready Remote Control
I can get this for about $630 CDN at a local audio store or on ebay for $450 CDN. Is it a bad idea to buy this on ebay since I can't check for any dead pixels until I get it?
I think that's a good deal, then! I especially like the 24 bit D/A converter and touch panel control. The wattage output per channel is normal, actually (not low output, that is). Most headunits put out about that much power. And there are a good deal of RCA outputs, so you'll be fine with that.
If you get it on ebay, just ask the seller if it has bad pixels (in the case it is used), or if you can return it should you find a dead pixel (in the case the seller cannot verify if pixels aren't working, say, on a brand new unit). I personally would get the one on ebay if you get the pixel problem worked out.
