Username: C0hpl Post Number: 9 Registered: Aug-09
Wednesday, April 28, 2010 - 13:07 GMT Hey guys, i've been doing a bunch of research and looking up all different types of subs etc etc.. I'm basically looking for a good subwoofer system that can hit the lows in rap songs.. I wanna keep it around $300.. 12"-15" Single or Double Ported + Amp Please let me know if you guys have any suggestions for a good "budget" Subwoofer setup Thanks!
Username: 813thumper Tampa,
FL
United States
Post Number: 158 Registered: Sep-09
Wednesday, April 28, 2010 - 16:54 GMT what do you already have? is that budget for everything? no one ever seems to be disappointed with type r's as a budget sub. but 300 for everything would be really tight
Username: Glasswolf Columbia,
SC
Post Number: 13179 Registered: Dec-03
Wednesday, April 28, 2010 - 17:39 GMT with that budget I'd go with used gear, and find something like an alpine type R sub or similar (single), I'd build my own ported box, and go with a used class D mono amp that can deliver about 600 watts RMS into the sub @ 2 ohms, making sure the sub I got was a single 2 ohm, or dual 4 ohm coil model sub. This is all assuming he already has a head unit that has sub pre-outs, or has a LOC for his factory radio.
Username: C0hpl Post Number: 10 Registered: Aug-09
Thursday, April 29, 2010 - 13:08 GMT I have all my wiring.. line out converter (stock head unit) So all i need is: Subs / Amp / Box.. I guess i could build a box, so that means $300 for Subs + Amp.. I was checking out craigslist and stuff, but i didn't see too much on there. LMK whats up, thanks again guys!}}
Username: Quirky San Antonio,
Texas
Post Number: 408 Registered: Feb-07
Thursday, April 29, 2010 - 14:31 GMT I would put the bulk of it towards a decent amp. Then perhaps you would have room to upgrade subs in the near future if need be. Going used is a must with this price range. Check out http://www.caraudioclassifieds.org/forum/ for some used deals What gauge wiring do you already have?
Username: C0hpl Post Number: 11 Registered: Aug-09
Thursday, April 29, 2010 - 16:47 GMT most of the people on there dont include shipping, so its kinda jacked up priced. And i have 4 gauge im pretty sure...
Username: Kyle_lowe Post Number: 1046 Registered: Apr-06
Thursday, April 29, 2010 - 19:42 GMT check these links, i didnt check the vc config of any of the subs so you will have to do that yourself http://www.caraudioclassifieds.org/forum/showthread.php?t=37944 http://www.caraudioclassifieds.org/forum/showthread.php?t=37994 http://www.caraudioclassifieds.org/forum/showthread.php?t=37611 http://www.caraudioclassifieds.org/forum/showthread.php?t=28798
