I finally got this dish on the sat. Then i try as i may i can get the rtn codes to go into the VS ultra Lite. I'm getting the CCTV channels but no RTN, I tried for awhile and nothing seems to work. I have a friend with a view sat ultra. If i can't get this then is there anyway to clone his receiver. Or if someone has a video on how to but these codes that would be great. HELP HELP, lol
Your friend can put the program the satellite list and the channels list in the upgrade menu on a USB Key then you only have to copy it in your receiver!
The instructions reference provider id 0106 - you would use the one(s) for rtn C801 C901
C/P
How to add provider ID- GO TO MENU, USER SETTING, CODE MENU SET CAS TO NAGRA CURSOR DOWN TO HIGHLIGHT SAT NAME AND ID NUMBER PUSH F1 ON REMOTE TO ADD PROVIDER ID NAME THE UNKNOWN SAT F2 TO SAVE FIRST SET OF ID NUMBERS ARE NOW HIGHLIGHTED, ENTER 01, THEN CURSOR RIGHT TO HIGHLIGHT THE SECOND DIGITS, ENTER 06, THIRD DIGITS ARE 00. iT SHOULD LOOK LIKE THIS, 01 06 00. tHIS IS THE NEW PROVIDER ID, DISH - 01 06 00 PRESS CURSOR UP TWICE, FIRST FF ON THE RIGHT OF WHITE LINE SHOULD BE HIGHLIGHTED. PRESS FAV BUTTON TO ADD ROWS OF FF'S UNTILL YOU HAVE FOUR ROWS, LIKE THIS;
THEN START ENTERING THE 0106 KEYS TO THE RIGHT OF THE WHITE DIVIDER LINE. ONLY EIGHT KEYS ARE USED PER ROW, THE LAST EIGHT ARE CHANGED TO 00, LIKE THIS;
08 3F AD 30 1F A0 CD 9E CE 00 00 00 00 00 00 00 00 09 54 69 8E 15 B3 65 09 FC 00 00 00 00 00 00 00 00 88 9F 41 6C AB 68 19 BA 98 00 00 00 00 00 00 00 00 89 2D 2E 77 FB 01 72 97 7A 00 00 00 00 00 00 00 00
another set of instructions say to press sat button to save after you enter the new provider and its ID
1) First, arrow left or right to pick the correct encryption protocol for the key you're adding, such as Nagra.
2) Hit F1 and enter the name of the provider.
3) Hit F2 to save it.
4) Enter the Provider ID.
5) Finally, you must hit the SAT button to save it (this isn't shown at the bottom of the screen like the other steps are).
----------------------------------------------------------------------------- Its easier with cw600s 'cause all you do is press page down and enter the key - no need to enter provider id
I tried the USB thing Plymouth but nothing worked....Loading those codes i must be making a mistake somewhere as it's not working....wow will plug away at it lol....might here me yelling where you live if i can't get it lol
The cw600s ...when on rtn channel press page down on remote ..edit keys with red button...you will need to enter the 00 key only..select OK when done...you may have to do this ( page down and enter keys)twice as the first time you enter keys it will be under nag2 and the second time it will come up as nag1 when you press page down..
I didn't see the lite in your post about the vs ultra,, it might not support N1.
Posted on Monday, April 26, 2010 - 03:04 pm: I finally got this dish on the sat. Then i try as i may i can get the rtn codes to go into the VS ultra Lite.
I only enter c801 for coolsat and with the cw600s I didn't even have to enter the provider id
I have a CW600p then look what I must enter in add new keys:
Red Button>00C801 00 E134079992603E3B>OK Red Button>00C801 01 AF96389F9259304A>OK Red Button>00C901 00 E134079992603E3B>OK Red Button>00C901 01 AF96389F9259304A>OK
