Citroen radio code
Username: Pol11
Hello, I'm hoping someone could help me obtain a radio code for a citroen xsara 2000 year serial nr CL0402Y0121279, MODEL PU2294B
Thanks
Username: Hay88
Post Number: 635
please look to see if you have an other barcode like c70000xxxx if so i can help.
Username: Pol11
e 13020410
286-8497-27
MA 27
96346 767 80
its everything
Username: Hay88
Post Number: 637
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with
C 7000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM
Username: Pol11
CL0402Y0121279 only this is on the metal casing
Username: Regrooster
Post Number: 3723
It will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
