Username: Dannyalasfar Post Number: 4 Registered: May-10
Tuesday, May 25, 2010 - 22:57 GMT I have 2 floor standing speakers and a subwoofer, all of which are relatively low power. I need an amp to put it all together but cant seem to find one that takes 2 speakers and a sub. If I bought a 5 channel amp can i just use 3 channels one of which is the sub? Danny
Username: Jan_b_vigne Dallas,
TX
Post Number: 14880 Registered: May-04
Wednesday, May 26, 2010 - 03:50 GMT . Seems a waste of money to do so. You only want a stereo amp? There are numerous models available. What's your budget? .
Username: Dmitchell Ottawa,
Ontario
Post Number: 3920 Registered: Feb-07
Wednesday, May 26, 2010 - 13:09 GMT The the sub passive (meaning there is no built-in amplifier) or powered? If the sub has it's own amp, all you need is a half decent 2 channel receiver or integrated amp.
Username: Nuck Post Number: 15025 Registered: Dec-04
Wednesday, May 26, 2010 - 23:05 GMT Does the sub have a cord to plug into a wall socket?
Ontario
Post Number: 3921 Registered: Feb-07
Thursday, May 27, 2010 - 00:26 GMT A better way of finding out...
Username: Dannyalasfar Post Number: 7 Registered: May-10
Thursday, May 27, 2010 - 00:45 GMT yes the sub is active! (cord into mains!) im looking at a receiver instead of an amp...
Username: Magfan USA
Post Number: 1182 Registered: Oct-07
Thursday, May 27, 2010 - 03:18 GMT Does the sub have speaker binding posts? If so, you're in....and can use virtually any stereo receiver that strikes your fancy.
Username: Dannyalasfar Post Number: 8 Registered: May-10
Thursday, May 27, 2010 - 10:53 GMT Well they are spring clips. I've picked one of these up for £25 from ebay, http://www.son-video.com/Rayons/HomeCinema/SystHCComplet/EltaxDAC280.html Rear view is 1st image down the left column, I just want to play music through a 3.5mm jack, a phono cable through aux1/2 will work fine right?
