Ordered Mine.. I ordered 30 of them and i learned a trick which is using an adhesive promoter which basically just strengthens the adhesive they DO have making up for what may be missing. They are on the way and i will def let ya know when i get em
I already have some, I got 15. I am very pleased with them. Mine had no problems with the adhesive, but maybe I just got lucky. I found them easy to work with. I used a small rolling pin and that worked just fine.
I actully threw a few more on after this picture. They work great. Much less rattle and i noticed a difference in both spl and sq.
