Need a new amp
Username: Lance86
Winnemucca , Nevada Us
I am on a budget for about 150-200 bucks....I am running a stock 96 blazer with 4 gauge wiring all around with a 12" pioneer premier ts 3001d2 two ohm speaker. I currently have a lanzar vibe251 1600W amp that sucks like crazy......if you guys could throw some names at me that would be greatly appreciated
Username: My_rantz
Australia
Post Number: 2273
Try the car audio section! Otherwise you may not like the names thrown at you :-)
Username: Artk
Albany, Oregon USA
Post Number: 10094
Head over to the car audio section and they will have plenty of free advice for you.
Username: Zeeal2
You really cant go wrong at a cheap rate with DUAL Deck....1 problem is your Guage wireing and no capasitor to dispurse the energy evenly through your wireing and will keep your wattage (RMS) which is about 610 RMS real watts from not enough signal to noise ratio to a normal peak.
RCA to RCA is at 1.2mlv ..your is at 15mlv ..way to noisy and over driven ...if I have you right....need more info not totally shure on your Q and what the problem
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 3775
spellcheck!
Ouch.
Username: Nuck
Post Number: 14887
Username: Dmitchell
Post Number: 3806
Is that your Mac Nuck?
