Making new box for 2 12 inch re audio se s please help?
Username: Bobby3342
Post Number: 35
i have gotten the design from re from greg(usampsfreak) but i wanna here suggestions
Username: Tanmanfosho
Post Number: 1192
hear*
and I'm not a box expert, but perhaps telling the fellas what you're planning on doing would be helpful.
Username: Rovin
1 15 = 152.5 DBs ...Trinidad & T...
Post Number: 16214
post the specs he gave u ...
Username: Bobby3342
Post Number: 36
36 by 13.5 high 25.5 deep 4 inch wide port 13 in long port
Username: Bobby3342
Post Number: 37
5 cubes tuned 35 hrtz
Username: Bobby3342
Post Number: 38
i have a photo i guess its design was on the old re website dont know how to post it
Username: Cwruck
Post Number: 109
thats a good design. if you like your "higher" sounding basses to be louder that would be perfect. but if you want like the song "hypnotize" by young jeezy and air forces and songs like that to bump hard drop your tuning to like 27 or 28. or if you like songs like "a milli" to hit hard keep it at that 35 or maybe even up to 37.
but if theres plenty of room for that box to fit in your car go for it, but if theres no room for it to let out the air i would say go a little smaller
2.5 for each sub is quite a bit for a 600 watt sub
Username: Bobby3342
Post Number: 41
really it s funny you say that airforces and hyptnotize hit the hardest in my car. i want to hit the meters well and still sound good
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 7653
personally i'd run 4 cubes @ 30hz with 56 square inches of port
Username: Bobby3342
Post Number: 42
id still be able to put up good numbers tuned to 30hz?frkkevin
Username: Bobby3342
Post Number: 43
whats the differnce bewteen 35 hz and 30 hz (in how it sounds?)
Username: 420pimp2
Baltimore Atlantic Ci..., MD, NJ
Post Number: 892
30 is deeper and 35 is higher ... i would stay between 30 and 33
