Aq1200d vs audiopipe 1500d
Username: Bobby3342
Post Number: 28
which will sound better?
Username: Wackzirth88
K-town, Il U.S.
Post Number: 358
idk if the sq will differ bewteen the 2. but in my opinion id say go with the aq
Username: Nd4spd18
Philadelphia, PA
Post Number: 11039
AQ is the better amp. Audiopipe makes crap
Username: Insearchofbass
York, Pennsylvania
Post Number: 13830
the signal to noise is much better on the aq so go with the aq
Username: Skdooley
Roanoke, VA Usa
Post Number: 507
There was a guy at the last car audio show I went to who had a PT Crusier filled with Audiopipe. I'm sure he'll be at the one today, I'll try to get some pics. I had never even seen the brand before until then.
Username: Nd4spd18
Philadelphia, PA
Post Number: 11041
They used to make crap wire, connectors, and accessories, now they make crap everything...
