Sharp 70" Acquos - Can't set up wireless
Username: Gringogary
Trying to set up my wireless - My network is detected and I am prompted to enter the security access code - When i start to use the keypad, it exits the menu and changes the channel. Can't find a way to enter the data without changing the channel.
Accidently figured it out. The manual says a keyboard is displayed when input required. However, you must hit <enter> to display it on the highlighted box. This little trick is no where in the manual.
