Will adding extra battery help my voltage drop? please help!!!!!!!!!!!!
Username: Bobby3342
Post Number: 45
i have a 2000 dodge intrepid stock alternator 130 amp 4 gauge wire duralast gold battery brand new 1000 cranking amps 2 12 re se d4s on audioque 1200d runnin at 1ohm. and my voltage sometimes drops to 11 volts but quickly goes back up but never below 11 but its all over the place my question is will adding a second battery help my voltage problem? or maybe a good capaciator (i have heard good and bad about them?) i know i need an better alt but thats 500 hundred dollars that i dont have so is there anyhting i casn do to help smooth out my voltage drop?
Username: Glasswolf
Lexington, SC USA
Post Number: 13354
http://www.glasswolf.net/papers/capacitors.html
http://www.glasswolf.net/papers/nocaplesson.html
http://www.glasswolf.net/papers/charging.html
