1 lnb 2 boxes?
Username: Tomoccfc
Hi all can anyone please help
you've probably already answered this question before but i cant find it, i have an lnb with only one output which is currently connected to my sky box, i also have a freesat HD box which i want to install but i live in an apartment in spain and can not get to the roof to swap the lnb, is their anyway of spliting the signal so i can use both boxes?
many thanks
Username: Lomna
Sac, Calif U.S.A
Post Number: 965
Wow....lol
Pray to God. He may help you.
Username: Plymouth
Post Number: 13658
tomoccfc
You can use the loop on back panel of your receiver, the problem with the loop is that you will be able to get channel on both receivers only if you choose a Vertical or a Horizontal on both in same time, choose different polarity will give the Horizontal channel in priority!
