Silver Member Username: LomnaSac, Calif U.S.A Post Number: 961 Registered: Dec-07 | I'm trying to use my 33" dish to get 119 with a extended arm ..when It is (33") already pointed at 118 with cb2008. There are two reasons I can't get 119 with cb2008 cuz my dish doesn't have skew angle secondly cb2008 can't pick up both sat with cb2008. DVR doen't like it. I'm trying hard to look into 119 with a second legacy lnb. I can easily see 110 and 129 but no 119. Is It cuz it needs to go exactly where my cb2008 pointing at 118 ??? If thats the case is there any way I still be able to get 119 without using a separate dish but on the my 33" dish together with 118 ??? I'm will greatful for your help. |
Platinum Member Username: NydasPost Number: 18754 Registered: Jun-06 | Devin: Read the details here. If you are pointing to 119 and getting it, you should be able to get it on two differnt settings as described in that long piece of information I put out. |
