Bronze Member Username: Ei_toro_the_great
Post Number: 85 Registered: Feb-10
Posted on History and Biography Plymouth I just check and found that they are both working. Freq. 12060 Pol.H Ser 25,700 3/4 they are listed as Eng. 11 Test and Eng. 12 Test |
Platinum Member Username: Plymouth
Post Number: 12931 Registered: Jan-08
Posted on Whiskey Sorry! They are back with a Hard reboot! I deleted my post but not the Thread!
Silver Member Username: Chaff
Post Number: 137 Registered: Jan-10
Posted on Plymouth , according to teddy this is big secret....according to you the providers will cut off or encrypt it now Or is it a bunch of BS |
Post Number: 13607 Registered: Jan-08
Posted on Chaff Those 2 channels are on all sites over internet but it seem that they keep it clear! Teddy is right about keep it secret which I endorse for many channels I founded not listed on usual site! |
Post Number: 138 Registered: Jan-10
Posted on but it seem that they keep it clear! I assume the same thing for those so-called secret channels. |
Post Number: 139 Registered: Jan-10
Posted on |
Silver Member Username: Bernardmi
Post Number: 792 Registered: Dec-07
Posted on Where on earth did Captain Midnight got is uplink equipment ? Not the dish... I am talking about the 14 GHz High Power transmitter ? Those cost close to a million !!!!
