Question
Username: Lauchie411
Inverness, Nova scotia Canada
Post Number: 117
What would be the issue, i ran all my cables from sat. starch one, then when i hook the cable from the dish into my VS ultra it powers of,as soon as i un hook the power is on....
Username: Plymouth
Post Number: 13627
laughlin
You have a short circuit on your cable, check inside the connector and see if there is not a little wire from shield which contact with the center wire!
Post Number: 118
ok will check tmr....ty
