I have a question...if I hook my surround sound up to me tv with all of the componets play through it? I have a ps3(HDMI) cable box(HDMI) 360(componets)....help! thanks
hi jt,, sound will play from your surround sound only turn sound off on your tv, and a hdmi to your tv for video only which reciever you using?
if your reciever has enough hdmi inputs and one output for your set up ok... but if it doesn't you'd have to hook up each source to your tv via best video cable and output avaliable..and digital sound to your reciever,
Thanks for your suggestion. I was also having the same problem. Yes, sound is playing from my surround sound only turn sound off on your tv. One more thing, I would like to know is that can increase my surrounding system ?
