ANYONE THERE NEED HELP
Username: Tulipe
Post Number: 184
friend of mine has pansat 2500 already has b75 flashing all the time . he needs it only for free to air . since he has only b75 flashing he need what loader and what bin to use so that he cam make it work only for true fta.
i never had pansat so i need help . direct me to the file and loader thanx
Username: Chaff
Post Number: 128
I would convert it back to a original 2500 with the b-60 boot file
Instructions here
http://www.ftabins.net/showthread.php?t=7476
Also I would load the pansat 2500 factory bin after the b-60 instead of the 294t bin.
ftabins probably has the factory bin .
Username: Pancho_vili
Post Number: 127
You can download the factory file here.
http://www.pansatusa.com/download.htm
Username: Tulipe
Post Number: 185
HOMBRE THE SITE IS DANGEREUX TO GO TO .
CHAFF I DONT KNOW WHY WHEN I DOWNLOAD BOOT 60 IT GOES TO %100 AND THEN IT SAYS DOWNLOAD FAIL.
WHAT BIN SHOULD I USE FOR B75 FOR 2500 MODEL .
Username: Plymouth
Post Number: 13581
Tulipe
Try it!
http://www.aaafta.com/forum/pansat-2500a-files/4419-pansat-2500a-boot-repair-kit -version-3-a.html
Username: Nydas
Post Number: 18707
Try and find Chancysand's Revert to B75 instructions and files and loader.
You need B75 boot not B60 boot.
Dsstester might have it. Many other FTA sites used to have this item.
Username: Tulipe
Post Number: 187
nalin i did find chency and i burned the receiver lol . now he got me an other box he found . ultralife that has night rider . you only see puff flashing nothing eles.
what loader to use and what bin to use so i can use it for true fta. i dont care about taking it back to the original state. just a bin so i can download channels . thanx friends.
Username: Dish1
Post Number: 16
nalin burns another reciever rlmfao maybe members will listen now
Post Number: 128
Tulipe
No more dangers then here.
The Pansat can only be used for true FTA
where is Gregraf? he was telling the newbies about
how Nalin has fried his receiver
Nalin.....said...Try and find Chancysand's Revert to B75 instructions and files and loader. You need B75 boot not B60 boot.
Tulipe.....said....nalin i did find chency and i burned the receiver lol
This will be the third one that I know of
Gregraf, sada and now Tulipe
Username: Nydas
Post Number: 18709
B60 was the original Pansat 2500 BIN. Chancysand's "Revert to 2500" sotware will do the job.
Here is an old C/P by Chancysand.
"Steps to Convert Back:
1.) With 2700 to 2500 Loader Converter.exe(included) load Boot60.bin(included) to box and
do not touch box when done it will reboot to nightrider and this is ok.
2.) Now open Blacklist Updater v1.4.exe(included) and load X-85BL_070812_294T_api.bin(included)
3.) Let the box reboot on its own and it should show "ON" in the display window.
4.) Now hook back up tp TV and it should have defaulted you into the menu at English. Hit "OK"
and then you are back to a 2500 again. "
At step 2 You could go back to a 274 BIN, but is is not necssary. The flashing is OK as Chancysand says in step 1.
Username: Juancho
CANADA Xx
Post Number: 858
cccccccccccccc, use any bin for the puff, but has to be puff lke this on your receiver
So if your receiver displays ( PUFF PUFF ) then you are to use the PUFF bins ONLY.
If your receiver displays ( P.U.F.F. P.U.F.F. ) with dots after each letter then you are to use the bins with (LZMA) in the bin name ONLY.
Just make sure it has for ex. Jvvh-Team-PUFF_(Lzma)_V207..
(Lzma) is what you look for in the bin name if you used the PUFF_Boot_VER1.0.2 or VER1.0.3 boot as loading anything else will get you stuck on " F. " until you load the proper bin to your receiver
Username: Tulipe
Post Number: 188
I GOT TO USE BLK LOADER 1.4 FOR THAT ???/
Username: Juancho
CANADA Xx
Post Number: 859
cccccccccccccc, yes use BL 1.4 don,t use boot 60, this boot was called assassins boot, any mistake ...jtag
Username: Nydas
Post Number: 18714
Juan: My understanding is that boor60.bin is the Pansat factory Bin and if you are in the PUF mode, you should first revert to that bin. To revert you have to use Chancysand's 2700 to 2500 Loader coverter.exe file as the loader. You will then get into nightriders and that is OK.
After that you use BL1.4 Loader - Blacklist Updater 1.3.exe to load a file like 294t.bin. That would remove the nightriders, Once he has got a linear LNB and scanned real FTA, he can change back to original BIN if he wants to.
Juan: Please correct me if I am wrong. I am not being antagonistic - just trying to get the right information accross.
Username: Juancho
CANADA Xx
Post Number: 860
From which boot revert to,. how many PUFF boots? How many P.U.F.F.boots? this it the problems. I don't know what kind of boot the receiver has.
After cccc load the correct .bin ,only then he'll knows what kind of boot it has.
For this reason I don't recommend boot60.
Do you remember the date Chancy post the revert file?
He post the file after the first P.U.F.F Lzma boot.
Then JVVH post a new 60 boot, then 1.0.1, 1.0.2, 1.0,3
Username: Juancho
CANADA Xx
Post Number: 861
Here is the first convertion to 2700, 60boot, all receivers that have this boot will have problems, this is the assassin boot, (do you remember how many fortec ,pansats,etc died, I remember on this forums, somebody post about being allied with DN.
Conver First Time From 253t..Light.2500 to 2700
CS_254T_PUFF_BOOT_Serial_Lightning 2500 to 2700
FIRST TIME HOW TO 2500 CS_254T_PUFF_BOOT_Serial_Lightning TO 2700
Do a factory reset or if you use Channel Master download your channel list, and alway scan B3V first.
D/N & B3V - A/R fix,
NOTE TURN OFF A/R and it will still A/R the new keys in
"READ" "READ" "READ"FIRST do a factory reset or delete all channel on bin file and use your own list or rescan
1. With Serial cable connected to STB and Booted up showing (ON) load BOOT_60 With 2700 to 2500 loader click on boot file only, hit download and after it's loaded you will get knight rider
2. With knight rider on box running, open & run BL 1.4, 2500 to 2700 or fortec JHD loader what ever one you used before
3. Then load CS_253T_PUFF_BOOT_Serial_Lightning.bin or any other jvvh253_ Puff_BOOT_Serial Bin (2 minutes to boot all the way up) DONE. NOTE THE 253T got PUFF in it
4. Then load the CS_254T or Jvvh254 and it load same way as you alway loaded the latest bin before
CS = Clone Safe
PUFF = New Boot File (can not go back to older bin files without Jtagging or reloading Boot60.bin)
Serial = Load from RS232 cable
Lightning = Background
T = Tivo Remote IR Codes
Username: Tulipe
Post Number: 189
THANX but when i loaded CS_253T_PUFF_BOOT_Serial_Lightning.bin after %100 download it says burn flash and i waited and then it says flash failed. i only have puff with no dot. when i turn it on it says puff then goes and only f show for seconds and then back to puff. im doing the for fortecstar lifetime ultra. i guess same process as pansat 2500. or i need different loader. i just want it to work for true fta.
Username: Juancho
CANADA Xx
Post Number: 862
Stuck on F.
This is happening because your crossing the compressed bins..and the need for the new bootfile..
-PUFF-boot_Ver1.0.2 is for use with Ukr_Jvvh-Team-PUFF_(Lzma)_V206 NOT Ukr_Jvvh-Team-PUFF_V206.
I put out the bootfile as a slight headsup b/c at the rate the bins are growing -PUFF-Ver.1.0.1 won't be much more use for long.
And to 'roll' back to puff you'd have to load the -PUFF-boot_Ver.1.0.1 back into your box then load in a PUFF type bin NOT Lzma..
here is la boot 1.0.1 this is the best boot 1.0.1
application/x-zip-compressedUpload
-PUFF-_boot Ver.1.0.1.zip (22.8 k)
for the .bins look for CanAm PUFFor CS Light.PUFF date Juan.22,2009 or Jan.23,2009
Username: Nydas
Post Number: 18720
Thanks, Juan.
