2 kicker 12" subwoofers 4 ohm
Username: Don92
What size & kind of apmlifier should i get to power my 2 12" kickers at 4 ohm?
Username: Skdooley
Roanoke, VA Usa
Post Number: 436
Depends on how much RMS you need.
Username: Glasswolf
Columbia, SC USA
Post Number: 12710
Kicker what?
CVR, CVX, CV, Solobaric L5, L7, Solo X?
Username: Don92
They are 12's, L5's, 4 ohms and 600 rms 1200 peak.
Username: Skdooley
Roanoke, VA Usa
Post Number: 439
If they are dual 4 ohm woofers they can be ran at 1 ohm or 4 ohm together. I'd say the best bang for the buck would be a AQ1200D. It'll give you 1200 rms at 1 ohm, rated power.
Username: Don92
so those 2 subs can be ran off that one 1200 watt amp?
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 296
Yep,and the aq1200 would be perfect for what you need.
http://www.the12volt.com/caraudio/woofer_configurations.asp#results
Just wire them like it has it in the top diagram.
