Silver Member Username: Vic123TorontoCanada Post Number: 165 Registered: Jul-06 | hey guys i have a 119/118 universal lnb set up, I pick 119 but how do i scan 118? Please help Thank You |
Silver Member Username: LomnaSac, Calif U.S.A Post Number: 945 Registered: Dec-07 | vic , you need large dish (33") and special lnb. post your lnb info.You need special lnb for 118. |
Silver Member Username: Vic123TorontoCanada Post Number: 166 Registered: Jul-06 | i do have d large dish setup i dont have d lnb info |
Silver Member Username: LomnaSac, Calif U.S.A Post Number: 946 Registered: Dec-07 | What it says on back of the lnb? |
Silver Member Username: Vic123TorontoCanada Post Number: 167 Registered: Jul-06 | im not sure its too late for me to go out and check right now |
Silver Member Username: LomnaSac, Calif U.S.A Post Number: 947 Registered: Dec-07 | Check it tomorrow and post it. I'm sure you have wrong lnb. Also can you be able skew your dish ? You need to skew your dish in order to get both(118/119) |
Platinum Member Username: NydasPost Number: 18682 Registered: Jun-06 | If you have not bought a LNB in the last two years, you do not have suitable LNB for 118. You need a 33" dish and this special LNB, which is only about $20 or less. Buy a dual one for two receivers - the price difference is only about $3. This LNB will give you both 118 and 119. You can mount your current LNB on an arm and point to 110. Add a disEqC switch ($5-8) if you don't have one and you are all set for three sats. Add a second disEqC and another receiver (when you are ready) and you have the same set up for your bedroom or your neighbour. |
Silver Member Username: Vic123TorontoCanada Post Number: 168 Registered: Jul-06 | devin it is all set up when i go to lnb type universal i pick 119 anik 3 and when i do a auto scan i only pick 119 channels. |
Silver Member Username: LomnaSac, Calif U.S.A Post Number: 948 Registered: Dec-07 | vic,what it says on the back of the lnb.? post it. When did you bought that one? |
Silver Member Username: Ei_toro_the_greatPost Number: 180 Registered: Feb-10 | vic..when i go to lnb type universal i pick 119 anik 3 and when i do a auto scan i only pick 119 channels VIC..........try this.......LNB Type set on standard A) do a Blind or Advanced Scan on EchoStar 7 at 119.0°W B) Now do a Blind or Advanced Scan on Anik F3 at 118.8°W If you can Scan Echostar 7, but no Anik F3 it can only mean that you don't have the combo.LNB or could be defectived. |
Silver Member Username: LomnaSac, Calif U.S.A Post Number: 949 Registered: Dec-07 | Whiskey,defective lnb is highly unlikly. they don;t go bad that easliy. It must be a wrong kind. Vic, post your lnb's info. |
Platinum Member Username: NydasPost Number: 18689 Registered: Jun-06 | What LNB you have does make a difference. One of the genric ones I mentioned is differnt from using a Dishpro Plus LNB. Unless you can give us an idea of the type of LNB you have and few other pieces of information - such as receiver you are using and the BIN, it is going to be diffiecult to get you going. Do not listen to Whiskey. What you said "when i go to lnb type universal i pick 119 anik 3 and when i do a auto scan i only pick 119 channels" is absolutely compatible with a generic type of LNB meant for 118/119. The following are the settings for a generic type of LNB. For 118 LNB type Universal (gives LNB freq 9750 - 10750) or LNB type Standard (use LNB freq 10600 - 10750) DisEqC setting will depend upon physical connection of LNB to it I usually use 1 for this type of LNB, because the Echo 7 is usally used with Port setting of 1. If you can do Blind scan, do it. Otherwise do a scan all with First TP of 11715. You may also go into Lyngsat and set up all the TPs, and do a scan all. Then separately set the LNB type as Standard and LNB Freq as 11750. and first TP as 12239 H. Do a Scan all. As I said before these instructions pertain to the generic type of LNB. For DPP LNB the situation is different, because you have separate outputs for 118 and 119, so you have to connect to Port 1(Echo 7) and 4(Anik F3) Also note that some of the genraic types of LNBs give a lot of channels with Universal 2 setting - becomes confusing. |
Silver Member Username: Ei_toro_the_greatPost Number: 182 Registered: Feb-10 | devin..........Whiskey,defective lnb is highly unlikly devin, I do agree with you,but I did say or could be defectived. I have change few in my time. Nalin Nyda....... Do not listen to Whiskey you answer him before I did did I bad mouth you? so why are you telling him "Do not listen to Whiskey" Are you here to help or to destory this Satellite TV Forum?} |
Gold Member Username: RtapFL Post Number: 2530 Registered: Jan-07 | Here's a basic guide that will help you choose the proper LNB for your setup of choice. DBS / DSS / Circular - LNB's are those used mainly for Echost*r and Nimiq satellites (61.5, 82, 91, 110, 119, 148). They have a LO frequency of 11.250 GHz FTA / FSS / Linear - LNB's are used for 121, AMC4, Galaxy25 (T5), Galaxy10R, Galaxy3, etc. They have a LO frequency of 10.750 GHz. Note: these satellites require a 30" or larger dish 118 / 118.7 - LNB's are used mainly for 118.8/119 Anik F3 LNBs or 118.7. They have a LO frequency of 10.750 GHz. Note: these LNB's are circular polarization and can also be used for all DBS/DSS type satellites including 61.5, 82, 91, 110, 119, 148, etc Universal - LNB's are a dual-band LNB often used for satellites in Europe. In North America, the only satellite that requires a universal LNB is Intelsat 9 (PAS9) at 58°W. Universals are a kind of linear LNB and can be used for any linear satellite. They have LO and HI frequencies of 9.750 and 10.600 GHz Invacom Quad Polar - LNB's are a special type used for mainly for motorized dishes. They are an all-in-one LNB, giving you both circular (DSS) and linear (FTA) polarizations at the same time REFERENCE SATELLITE SETUP For Circular Satellites: 61.5W Echo3, 77W Echo4, 82W Nimiq2 (HD), 91W Nimiq1&3, 110W Echo 10/11, 119W Echo7, 121W Echo9, 129W Echo5 (HD), 148W Echo1/2 You need: Circular LNB, LNB Type = Standard/Single, LNB Freq = 11250Mhz, typically a Smaller 18 to 22 inch dish For Linear satellites: 63W estrela, 71.8W nahuell, 79W amc5, 91W galaxy11, 93W intelsat6, 95W galaxy 3C, 97W intelsat5, 101W AMC4, 103W AMC1, 105W AMC15, 107.3W Anik, 111W Anik f2, 116.8W Satmex5, 123W Galaxy 10r, 127W Galaxy13 You need: Linear LNB, LNB Type = Universal/Standard, LNB Freq.= 10750Mhz, typically a 30 inch dish or larger dish For AnikF3 - 118.7 ---> You need: Special LO frequency LNB -- LNB Type: Universal (or Standard) -- LNB Freq: 10750 MHz For Quality Use TP: 11715 Scanable Channels: Clear 1, Encrypted 81 (DN)(HD 19) Minimum dish requirements = 30 inches and above. C/P Topwiz __________________ Gigster |
Platinum Member Username: PlymouthCanada Post Number: 13535 Registered: Jan-08 | vic You must see it on your LNB: circular(118W) Input Frequency Range from 11.70Ghz ~ 12.75Ghz Output Frequency Range from 950Mhz ~ 2000Mhz A standard circular LNB: Frequency Input Freq. Range 12.2 ~ 12.7 MHz Output Freq. Range 950 ~ 1450 MHz |
Platinum Member Username: NydasPost Number: 18691 Registered: Jun-06 | RTAP: This thread is about 118/119. Can you see tha on the title. Now please confine your comments to that topic after reading what has been said. You are masking a lot of information just to posta long post to show your knowledge. You did that 2 years ago producing a long list in response to request for one item in the list.. |
Gold Member Username: RtapFL Post Number: 2531 Registered: Jan-07 | nalin if u see this info shows and explains info on 118.so he can use for future reference.i guess trying to help is wrong here if its not u or plymouth. funny how u havent said a word about refering people to the sites that have been busted huh hmmm 118 / 118.7 - LNB's are used mainly for 118.8/119 Anik F3 LNBs or 118.7. They have a LO frequency of 10.750 GHz. Note: these LNB's are circular polarization and can also be used for all DBS/DSS type satellites including 61.5, 82, 91, 110, 119, 148, etc |
Gold Member Username: RtapFL Post Number: 2532 Registered: Jan-07 | ohh and dont precede to tell me what i can and canot post here u mean sheit to me and your supposed knowledge even less lmao |
Platinum Member Username: PlymouthCanada Post Number: 13537 Registered: Jan-08 | RTAP currentbins was diffused by many other sites before that we diffused it here! Those org site was good until the raid was made then goes as high that 20,000 to Alexa rank! This is a big lost for satellite community! Your comment about it look like a bashing on us! |
Gold Member Username: DoreenakadjCanada Post Number: 4261 Registered: Dec-06 | You are masking a lot of information just to posta long post to show your knowledge jealous much? sounds allot like what you do to Nalin. except you post long winded posts to be see not understood. for post counts only |
Gold Member Username: DoreenakadjCanada Post Number: 4262 Registered: Dec-06 | Plymouth Your comment about it look like a bashing on us! EVERYONES comment looks like a bashing to you two because you only want to be the ones thats posted the right info and everyone else is wrong. your accusations |
Platinum Member Username: PlymouthCanada Post Number: 13539 Registered: Jan-08 | ""Invacom Quad Polar - LNB's are a special type used for mainly for motorized dishes. They are an all-in-one LNB, giving you both circular (DSS) and linear (FTA) polarizations at the same time"" |
Platinum Member Username: NydasPost Number: 18693 Registered: Jun-06 | RTAP: I can and will tell you when you post an irrelevant long post to obsure my post. While you were gallavanting to your menotr PRFRMJN's site we were helping people here as much as we could in spite of interruptions from "the Fun Bunch". Now we do not wnat to be stymied by another "irrelevant bunch". Behave properly when you are answereing on the forum. Remember that I always considered you a good helper somewhat taken aback by LK and somewhat out of the hero worship mould. Stay precise to the point and you will be OK. |
Silver Member Username: LomnaSac, Calif U.S.A Post Number: 950 Registered: Dec-07 | where are you VIC ??????? A bunch of knowledgeble people wanna people you here but you are just vanished away lol.. |
Silver Member Username: Vic123TorontoCanada Post Number: 169 Registered: Jul-06 | Ok now im soo confused, I purchased this LNB 2 weeks ago. I have d big dish set with 3 lnb's 91,110 and universal for 119/118 for my limesat, and also on my anntena set up there is no 118 on d list LNB info please advise if its d right 1 thank you: Model: GK832 - 10 Noise Figure: 0.4db Input: 11.7 - 12.75 GHz L.O: 10.75 GHz S/N: 83210-0108-000 7057 Please advise if this is d right LNB |
Platinum Member Username: PlymouthCanada Post Number: 13553 Registered: Jan-08 | vic You has the right LNB! |
Silver Member Username: Vic123TorontoCanada Post Number: 170 Registered: Jul-06 | so why am i not getting 118 for international cahnnels what am i doing wrong :'( |
Platinum Member Username: PlymouthCanada Post Number: 13557 Registered: Jan-08 | vic Use this setting! 118.8W Anik F3 LNB:on LNB Type: Universal LNB Freq: 10600 TP Freq:12063 (H) Check if you get a signal with those setting then align your dish to get the stronger signal and quality. Try also TP Freq: 12081 (V) and try to get the stronger signal on those 2 TP Freq.! Do a auto scan with those info! Tell me which receiver you use? Tell also if you have in your satellite setting both satellites (118,8W and 119W). |
Silver Member Username: Ei_toro_the_greatPost Number: 183 Registered: Feb-10 | VIC.........Ok now im soo confused, I purchased this LNB 2 weeks ago. I have d big dish set with 3 lnb's 91,110 and universal for 119/118 for my limesat, and also on my anntena set up there is no 118 on d list vic, you need to add Anik F3 at 118.8°W and Transponders to your Antenna set up then do a Scan. when you change lnb you have to change settings in your receiver to the type of lnb you are using. so go to menu find dish settings and change lnb type setting |
Platinum Member Username: PlymouthCanada Post Number: 13559 Registered: Jan-08 | vic Ok! I missed your post! Do a scan on 119W with the setting I posted above then after use this setting: LNB Type: Universal LNB Freq High: 11250 LNB Low: 10750 It would be(LNB Freq: 10750/11250) You will get both satellites with 119W No need to create 118.8W! |
Platinum Member Username: NydasPost Number: 18702 Registered: Jun-06 | If Limesat has a Blind scan available, he does Blind scan of 119 using LNB frequency of 10600. Then another Blind or regualr scan of 119 using LNB freq of 11250 of Echo 7 sat. If he does not have a slate for Anik F3 he can also add another Sat and add the TPs for it and then do the regular scan of that sat using 10600 or 10750 The LNB he has is amenable to using Universal 2 setting of 9750-10750 and might work better with that setting. The way to scan is either e Blind scan (ignoring the TP list) with the dish pointing properly, or a full scan with a full list of TPs in the TP list. The Echo 7 is scanned using the same LNB with a LNB frequency of 11250 |
Silver Member Username: Ei_toro_the_greatPost Number: 184 Registered: Feb-10 | Vic says............hey guys i have a 119/118 universal lnb set up, I pick 119 but how do i scan 118? Plymouth says.....No need to create 118.8W! Whiskey says................I would think that, two birds, Anik F3 at 118.8°W and EchoStar 7 at 119.0°W different Orbit location, different transponders would need two separte Scans. echo 7 LNB Local- Freq.=11,250 Circular Anik F3 LNB Local- Freq. = 10,750 Linear |
Platinum Member Username: PlymouthCanada Post Number: 13562 Registered: Jan-08 | Plymouth Platinum Member Username: Plymouth Canada Post Number: 13559 Registered: Jan-08 Posted on Wednesday, March 31, 2010 - 10:19 am: Edit Post vic Ok! I missed your post! You will get both satellites with 119W No need to create 118.8W!} |
Gold Member Username: DoreenakadjCanada Post Number: 4286 Registered: Dec-06 | Vics question = I pick 119 but how do i scan 118? Whiskeys Answer = echo 7 LNB Local- Freq.=11,250 Circular Anik F3 LNB Local- Freq. = 10,750 Linear Pltmouths answer = You will get both satellites with 119W No need to create 118.8W My question = I thought 118 was all HD channels so wouldn't you need 2 different LNBs? Just wondering. |
Platinum Member Username: PlymouthCanada Post Number: 13564 Registered: Jan-08 | 118 was not all HD channels then No you don't need a special LNB to get HD channels on Dn! vic LNB can get all channels HD and SD! |
Silver Member Username: LomnaSac, Calif U.S.A Post Number: 951 Registered: Dec-07 | HD are available only on dn's 77,110 and 129. No HD on 119 or 118. Plymouth is right on 118.8w. Blind scan will get you that, make sure you blind scan the low freq 10750 |
Gold Member Username: DoreenakadjCanada Post Number: 4297 Registered: Dec-06 | I saved these links awhile back hope this helps https://www.ecoustics.com/electronics/forum/home-video/459196.html https://www.ecoustics.com/electronics/forum/home-video/513667.html |
Silver Member Username: Vic123TorontoCanada Post Number: 171 Registered: Jul-06 | Ok guys so i managed to get some international channels But i only get 3 indian channels like zee cinema, set max and b4u music. how about d rest how do i get tht??? Please advise am I scanning the wronng TP I did LNB type - Universal and only managed to get 3 indian channels :S |
Platinum Member Username: PlymouthCanada Post Number: 13576 Registered: Jan-08 | vic How is the signal and quality on those channels? |
Silver Member Username: Pancho_viliPost Number: 126 Registered: Feb-10 | Doreen Check this out and tell me what you see? https://www.ecoustics.com/cgi-bin/bbs/show.pl?tpc=2&post=1487756#POST1487756 |
Platinum Member Username: PlymouthCanada Post Number: 13579 Registered: Jan-08 | Esvaldo You Hijacked this thread! |
Silver Member Username: Vic123TorontoCanada Post Number: 172 Registered: Jul-06 | signal quality is beautiful Q 88 and S 83 |
Platinum Member Username: PlymouthCanada Post Number: 13580 Registered: Jan-08 | vic Try a blind scan! You only get those channels or you are only able to see those channels? |
Silver Member Username: Pancho_viliPost Number: 130 Registered: Feb-10 | vic..signal quality is beautiful Q 88 and S 83 Because you are pickup the TPs on EchoStar 7 at 119.0°W and not on Anik F3 at 118.8°W Vic.......list some of your TPs Frequencies and channels that come in strong |
Platinum Member Username: NydasPost Number: 18710 Registered: Jun-06 | Vic you have not told us what receiver you are working with, and what BIN do you have? |
Silver Member Username: ChaffPost Number: 129 Registered: Jan-10 | Nalin ..yesterday vic posted he was using limesat ...it could be different today , who knows ? |
Silver Member Username: Pancho_viliPost Number: 132 Registered: Feb-10 | VIC Posted on Wednesday, March 31, 2010 - 01:33 am: -------------------------------------------------------------------------------- Ok now im soo confused, I purchased this LNB 2 weeks ago. I have d big dish set with 3 lnb's 91,110 and universal for 119/118 for my limesat, and also on my anntena set up there is no 118 on d list Nalin Nyda Posted on Thursday, April 01, 2010 - 09:54 am: -------------------------------------------------------------------------------- Vic you have not told us what receiver you are working with, and what BIN do you have |
Bronze Member Username: BackdoorPost Number: 60 Registered: Jun-06 | will this 118.7 & 119 work in aruba also with dish 1.8 and sonicview premium 360 if yes what lnb do i need have the eagleaspin |
Bronze Member Username: BackdoorPost Number: 61 Registered: Jun-06 | i get 119 ecco 7 but no 118.7 |
Platinum Member Username: NydasPost Number: 18711 Registered: Jun-06 | Vic: Sorry I did not see that you do not have Anik F3 in your list of sats. That is not a problem. Look at your manual and see if you caN SET UP a new Sat in your sat list. Alternatively use any spare list. I have often used the ANIK F2 list. Use LNB freq of 10750 LNB type single or Standard. Insert one TV in the new list - 11715. Do a Blind scan If this does not work, insert the If you have the full TPlist then do a full scan and not a Blind scan. You may try Universal setting for LNB type. Scan Echo 7 separately in the 119 slate using TP freq of 10750 and LNB type standard or single. |
Silver Member Username: Vic123TorontoCanada Post Number: 173 Registered: Jul-06 | GUY all up and running beautifully freeze free Thaaannnkkkk yooouuuu alll for you help u guys r awesome LONG LIVE FTA wooohoooo |
Platinum Member Username: PlymouthCanada Post Number: 13592 Registered: Jan-08 | vic Good news! |
