SonicView "Please update the newest SW "
Username: Hello2k3
Post Number: 39
Stuck on one channel, whenever I try to change the channel I get this message "Please update the newest SW". Anyone else having the same issue? or found a solution?
Username: Archizart
yes, I have this same problem and I have't any channels!
Username: Juancho
CANADA Xx
Post Number: 864
anyway is better donwload the last SV .bin if that doesn't fix your receiver at least its ready for private server.
As the SV 8000HD .. HD8000_P_02APRIL2010_v505_b207
is ready for N3XT,just look for some private server,and tv ready
8000HD works, I don't know about SV360 ,but the option is there.
Username: Pancho_vili
Post Number: 144
FTABins.NET - Current FTA Receiver Status
FTABins.NET FTA Status Page V3.0
LAST UPDATE: SUNDAY 04/04/10 01:06 am BY: TECH
http://www.ftabins.net/status.php
Username: Juancho
CANADA Xx
Post Number: 865
If you don't have imagen.status mean nothing
Username: Crazycool
Post Number: 107
What's the new file 405?
Username: Nydas
Post Number: 18735
Echo v. Sonicview
Order on Motion for Preliminary Injunction filed March 29, 2010
The court has ruled that Sonicview is prohibited from designing, manufacturing, selling, distributing marketing etc, 8PSk Turbo Boards and the Ihub. Sonicview argued that third parties are responsible and that they should not be held accountable for their actions.
