Renault Clio radio help
Username: Garton
Right, so I have bought a standard tape player for my 99 Clio and have the code! But I don't know what I am doin with the code as I have to display to look at. I have searched and searched and nothing mentions no displays. Any help would be gratefully recieved! Thanks, adam
Username: Hay88
Post Number: 256
hi
dont know if this will help you but.
say your code was 1234
have you push button 1 2x in case the first is a 0. so to get number 1 push 2x then push button number 2 3x to get to 2 so on and so on.
it may be the case where the first push is 0
FOR NO STEERING CONTROL
press the first preset button for the 1st digit,
second button for the 2nd digit
third button for 3rd digit
forth button for 4th digit
then press buttons 6 OR 5 to store. for 10 seconds
note the radio does not lockout after a wrong code entry it only doubles the time to wait before
the next retry...if a wrong code is entered it will display error then after the delay should display "0000")
