Username: Hdave555 Post Number: 12 Registered: Nov-07
Saturday, March 27, 2010 - 23:46 GMT Can some one give antenna settings for VS ultra 110 & 119. I have dish 1000+ and i get no video and audio.
Username: Plymouth Canada
Post Number: 13487 Registered: Jan-08
Sunday, March 28, 2010 - 00:43 GMT Harry LNB Type: OCS-DP LNB Freq: 12384 Do you have signal?
Username: Hdave555 Post Number: 13 Registered: Nov-07
Sunday, March 28, 2010 - 01:03 GMT Yes i have full signal but i only quality on one Port. I have also have DN which works fine with same setting and i have DP44 switch. i know there are many smart people in here who can help me PLzzz help me guyzzz
Username: Kbox Post Number: 171 Registered: Jul-09
Sunday, March 28, 2010 - 01:11 GMT Port. I 119 Port. 2 110
Username: Hdave555 Post Number: 14 Registered: Nov-07
Sunday, March 28, 2010 - 01:24 GMT i have set up that way but no luck.
Username: Kbox Post Number: 173 Registered: Jul-09
Sunday, March 28, 2010 - 01:29 GMT DP44 switch the power the lilttle box have to be on port one to power it up
Post Number: 13492 Registered: Jan-08
Sunday, March 28, 2010 - 01:37 GMT Vs Ultra not work properly with a Dp-44, use a diseq switch!
Username: Hdave555 Post Number: 15 Registered: Nov-07
Sunday, March 28, 2010 - 01:44 GMT Kbox i do not understand you comments what are you asking me to do. can you please expain it more in detail or give me steps. plymouth: i have spend 100 to get this switch so i like to user this. i know there might be someone who is using this switch and its working for them.
Username: Kbox Post Number: 175 Registered: Jul-09
Sunday, March 28, 2010 - 01:47 GMT Plymouth the diseq switch yes it work good with diseq switch
Username: Kbox Post Number: 176 Registered: Jul-09
Sunday, March 28, 2010 - 01:53 GMT http://www.aaafta.com/forum/viewsat-9000hd-help/9859-viewsat-hd-dish-1000-setup- s.html
Username: Hdave555 Post Number: 16 Registered: Nov-07
Sunday, March 28, 2010 - 01:53 GMT i had that switch before i had dp44 and i had same problem. so i swithc to dp44
Username: Nydas Post Number: 18665 Registered: Jun-06
Sunday, March 28, 2010 - 15:07 GMT You will generally find that DP44 and DP34 work best with DP LNBs and receivers and the DiseqC is best with standard LNBs and FTA receivers. There are many exceptions to this statement - I am simply saying that this is a general rule you should have when you are making a quick decision.
Username: Nydas Post Number: 18668 Registered: Jun-06
Sunday, March 28, 2010 - 23:53 GMT Yes
