Anyone knows how to solve this ???
Username: Tulipe
Post Number: 167
i instaled trend micro internet security for 30 days trial and after 30 days i did the unistalation . so i can do an other 30 days. even i cleaned all trend from my system still telling me that trend product is already in this system. after i did add/romove program . i did search about anything trend i del,,eted it . and went to the registry delete any file trend . but still any help thanx
Username: Pancho_vili
Post Number: 110
Tulipe, since you are an old friend of SatScanner's
I will help you. Try System Recovery.
Username: Doreenakadj
Post Number: 4212
Trend Micro Internet Security ? I can get you a cracked version and its pro 2010
PM for the links
Username: Sump
Post Number: 994
you must go into the registry to clear out the entry .. NOT for novice
go to cnet.com .. downloads ...
get "avira" anti virus free version or "AVG" free version
load either one of those you fine ..
also add "super anti spyware"
between those two they get most all
Username: Sump
Post Number: 995
hi doreen !!
Post Number: 111
sump or Doreen
tell me, in Windows Live Calendar how to change the date?
now it's on March 18, 2010
Post Number: 4213
hey sump whats up?
Microsoft appears to be taking a cue from Google, and is rolling out its latest web service to just a few Windows Live users at a time. LiveSide reports that some folks are able to access the new Windows Live Calendar today, while others will be taken to Hotmail or MSN Calendar if they follow that link.
The updated calendar application seems to be a decent Google Calendar competitor, with many of the same features:
Day, Week, Month, and Agenda views customizable by name and color
Create multiple calendars
Share your calendars with other Windows Live users
Receive email reminders of scheduled events
Share calendars via xml
Import ICS files from Outlook, Google Calendar or other calendar apps
There's no way to synchronize calendars. Yet. But LiveSide reports that Microsoft is working on the ability to synchronize your Windows Live Calendar with Outlook and/or Windows Mobile. And that could make this a killer web app. Right now you need a third party solution like GooSync or GMobileSync to synchronize a PDA or phone with Google Calendar.
Post Number: 4214
hombre try this link
http://calendar.live.com/calendar/calendar.aspx
Username: Nydas
Post Number: 18655
revouninstaller is a very good/ uninstaller to remove the last vestigies of a file.
I use version 1.80 which I find more satisfactory than the later versions. If you google specifically for this version you may be able to locate it.
Username: Nydas
Post Number: 18656
Advanced Window Care version 2 (2.9) is a good software to clean out registry. I use it without concern and let it remove 100's of registry entries it finds undesirable and have not regretted using it that way.
I use version 1.29 and the website now offers me a later version which I avoid. If you google specifically for this version you may be able to locate it.
Post Number: 4217
http://hotfile.com/dl/30875578/82e5f09/TrendMicroInternetSecurityPro2010.rar.htm l
here get the pro
Trend Micro Internet Security Pro 2010 v17.5 x32 x64 Trialer Reset included
Username: Plymouth
Post Number: 13478
Do a search with "Trend Micro Internet" and deleted all files which link to it!
Download Regcleaner and do a clean with it!
Username: Tulipe
Post Number: 169
I DID ALL THE ABOVE nothing is working . i even restored the system to an old day . wht it says is you have already trendmicro program instaled in your system. i looked evety google search . many poeple say many stuff that did not work for me .
doreen by the way when i tried to instal the trend pro .it says that i can get this version.
a while ago i have been instaling trend free trial and remove it and reinstal it . it has been like year now but trend decided to to allow me .
some suggest an other antis virus . my answer is noooooooo
trend is great becuz does not slow the system it makes it faster and it's good product.
my last hope is that im going to wipe and reinstal the windows which is great pain for me .
Username: Tulipe
Post Number: 170
here is what i get trying to instal trendpro doreennnnnnnUpload
Post Number: 4222
if you reinstalled it you have to uninstall again.... then reboot your computer ... make sure your time and dates are right.... then install the one I gave you.
going by your picture , your system says its still on your computer.
Try systems restore... go back to the date b4 you first tried to remove the Trend Micro Internet Security...after its been restored... uninstall it again... then install the one I gave you.
one other thing I can try to do for you is get the serial code for you .. I will need the year .. (I gave you 2010) is your 2009?
I hope this helps
Username: Sump
Post Number: 997
cccccccccccc
it is a registry thing as i said .. and it not for the NOVICES to mess with ..
just use either one of the recommendation s i made and you will have virus software on your PC done in 10 minutes ..
Post Number: 115
Si Si
If the above don't work you have three 3 choices left.
A) Full System Restore
reinstall all factory shipped files
B) buy a new computer
C) they gave you a free-bee
you liked,now pay the man
for more
Post Number: 4223
B) buy a new computer >>>> LOL what ever for?
Post Number: 4225
ccccccccc....here are some reg. clears for you to try .... they are all PORTABLES no need to install them. all are working. If you use win.7 they may not work for you though.
http://rapidshare.com/files/368783533/reg_clears_portables.rar.html
Post Number: 4226
Trend Micro™ AIO 02.01.2010
Trend Micro™ AIO 02.01.2010 | 234 MB
Collection Trend Micro™ update 02.01.2010
Trend Micro Internet Security Pro provides the most comprehensive p
Trend Micro Internet Security Pro provides the most comprehensive protection available for your personal and financial information -- whether you’re at home or on the road.
The Official Pattern Release or OPR is Trend Micro's latest compilation of patterns for identified viruses. It is guaranteed to have passed a series of critical tests to ensure that customers get optimum protection from the latest virus threats.
This pattern file is most effective when used with the latest scan engine. We strongly encourage you to update your scan engine to ensure you are using the best virus protection available.
Trend Micro AntiVirus + AntiSpyware is the essential security you need to safeguard all your data and files. With automatic scans, updates and outbreak alerts, you can rest easy knowing you have systematic, ongoing protection against the latest malicious viruses, worms, Trojan horse programs, and spyware.
http://hotfile.com/dl/26806228/db15228/Trend_Micro.part1.rar.html
http://hotfile.com/dl/26806227/45568ee/Trend_Micro.part2.rar.html
http://hotfile.com/dl/26806229/d978d97/Trend_Micro.part3.rar.html
Try this too
Username: Tulipe
Post Number: 171
THE PROBLEM here is not downloading trend. the problem is not accepted by the system . againnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn no matter what i do it says i still have trend in my system.
i did try to instal AVG and it detect that trend in my system and ask to remove it first by clicking one icon that takes me to romove/add program but there there is no trend there to remove . it's like a ghost. some registry cleaner did not do anything .
Post Number: 4231
so reinstall the trial version ... the first one... then try the avg
I don't understand why its giving you such a hard time ... maybe messing with the register keys wasn't a good idea like sump warned you about.
anyway for now since there isn't a anti virus program on your computer, I would back up anything you want to keep like pictures Doc file anything that means anything to you.
Post Number: 4232
cccccc....check your email I PMed you again
Username: Plymouth
Post Number: 13484
Tulipe
Listen Doreen is not the best thing to do!
She kill many computer with her files, do a search on it!
You are warned!
Post Number: 4233
Name one computer I crashed you fool Plymouth. Why are you spreading rumors like that about me .. What ...now you are a computer genius too as well as an expert on Fta etc.. you are a fu-king joke ...just 2 year under your belt with fta and i bet you know nothing about computers gong by some of your posts trying to help.. so STFU for once and stop your BS! You are to retarded to realize just how foolish you make yourself look like to others here.
I am sorry you have a mental handicap with having A.D.H.D and all. I also understand why you can't understand things like a normal person can . But I have had it with you childishness.. even kids with A.D.D grow up .. don't you think its time you did?
Post Number: 4234
btw stupidmouth .. tell me ....if I kill computers .. why do I get PMs or emails from members here asking for my help or for files over and over again.. HUH?
YOU KNOW NOTHING except how to spread rumors and lie!!!!
Username: Guru4u
El Centro, Cali Baby
Post Number: 58
playmut is dn mole be warned!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
Username: Guru4u
Post Number: 59
he is gathering ip's for charlie
Post Number: 4235
like i care .. i pay for my bell tv I have the bills to prove it. I don't pirate/steal tv signals unlike stupidmouth himself and numnuts. They are no here 24/7 braging about how to steal TV signals using namy receivers.
Do you see me talking about that this past year or so? .... NO.... i talk about computers and computer software. Its not the same thing.
BTW I warned members here namy times about nfusion and Iks notbeing trusted... Thats why stupidmouth and numnuts directed members to there stupid ORG sites ( to get their IP addresses)... Now sh!t is hitting the fan. and I don't mind saying I TOLD YOU SO!!!
Username: Plymouth
Post Number: 13491
Miss B1tch!
You post illegal files on this site!
You must read the rules!
Post Number: 4236
you post illegal ways to hack into Charlie stupidmouth... so stop being a hypocrite!!
Username: Tulipe
Post Number: 172
OHHHHH NOOOOOOOOOOOOOO plz guys dont distrupt my thread. plymouth i know u r great but leave doreen alone all she does is trying to help i know her since 2004. beside she is cute and real womean u can count on her really . she is not trouble maker at all. she is a darling . i love you all guys no profanity cuz it not what we are here for.
doreen even when i try to reinslal the free trial thia is the error it gives me . you habe alreay some trend product instaled if u continue witrh the instalation it may not be susseful . when i continued it does not go.
Username: Tulipe
Post Number: 173
plymouth be nicevto doreen she is a darling . be a gentelman and dont screw my thread plz.
Username: Casual_the_voice
Post Number: 33
Doreen, you are losing your touch
This person by the nick Plymouth
keeps calling you a B1tch.
why don't you report him to the owner of this site?
calling a woman member a B1tch
Username: Nydas
Post Number: 18663
Tulipe: I tried to tell you what the right approach is, but you seem to be focused on one person (Doreen).
When you install some of the more recent software, even the sophisticated un-installers cannot get rid of the remanants that the program deliberately leaves in your computer - they are like viruses which only affect a little part of your body. when you attempt to install a trial version again they prevent you.
Use Revo Uninstaller or similar in the highest cleanout mode and you might succeed in removing these vestiges of programs which behave like viruses. Normal virus cleaners will not clean it out, Then use the registry cleaner to remove anything that the Uninstaller missed - I suggested AWC 2.9 and there are other Registry cleaners. The Registry cleaners I have come accross are in two versions free and paid. That is why I use AWC2.9 a product which was taken over and replaced with a paid version 3.
It is only after this cleanup that you will able to proceed.
Username: Tulipe
Post Number: 177
nalin thanx for the advise. i did not mean to ignore what u wrote it;s sometimes i answer the thread before i got your instruction. i wiped the hard drive and rinstal xp and instal again the free trial .
doreen thanx i did instal the fre trial pro .
now i need from you the recovery software for my scandisk 4G. by mistak i left it conected to the computer while the wipe drive was cleaning the drive and started to wipe the scandisk .
i trial ddr drive recovery but the demo dont give the choice to save the data. asking to purshase. thank you all................lol
Post Number: 4242
scandisk 4G and ddr drive recovery ? Not sure what you mean .
If you want a good data recovery software try
Recover My Files data recovery software will easily recover
deleted files emptied from the Windows Recycle Bin, or lost due to
the format or corruption of a hard drive, virus or Trojan infection,
unexpected system shutdown or software failure.
Install Notes:
1. Unpack & Install.
2. Replace all files. (EXE, DLL and FFF.NFO file)
Note: Don't forget to copy FFF.NFO into the install directory or
software will not works.
http://netload.in/datei4M2YULzB8E/GetData.Recover.My.Files.Pro.Edition.v4.4.8.57 .rar.htm
file works I use it sometimes
Post Number: 4243
Jennifer I am not responding to some ignorant post made by some immature A.D.H.D pond scum
the admin ignores me every time I complain so its a waste of my time. He will get whats coming to him in the end.
Username: Nydas
Post Number: 18684
Jennifer Conus said on on Sunday, March 28, 2010 - 10:30 am:
"Doreen, you are losing your touch ..... B1tch.
why...... you r...... a B1tch"
Post Number: 4250
oh now that makes allot of sence........not!!!!!
Username: Ei_toro_the_great
Post Number: 181
Poor Jennifer
Nalin Nyda
Nalin
why are you lying........Jennifer Conus Did not say that
Jennifer Conus C/P above
calling a woman member a B1tch"
Jennifer Conus was talking to Doreen about Plymouth
Sir what seem to be your problem?
Username: Tulipe
Post Number: 180
i opened the thread for a purpuse not for hijacking my fuckkkking thread . and insulting doreen . nalin and the whisky or anyone have life i was the master in this ecoustic about insulting and making trouble . i quit simply becuz i have a life. so fuckkkkkkkkkkk all of you who dont respect my thread . thanx doreen
Username: Tulipe
Post Number: 181
doreen the site did not allow me to download. they want me to pay for premium download . the regular download did not allow me i keep hitting on download and it did goe no where .
im talking about removble drive . i need this recovery for my scandisk remouvble drive that has 4G of memory.
Username: Plymouth
Post Number: 13536
Tulipe
Do a search on Cnet!
http://download.cnet.com
Username: Tulipe
Post Number: 182
doreen usb flash drive scandisk
Post Number: 4255
ok try this one
http://depositfiles.com/en/files/ok3b40ovd
USB Flash Drive Data Recovery 7.0 20:02
USB Flash Drive Data Recovery Software is a useful application that will enable you to get back lost or deleted data from your portable devices.
USB Flash drive data restoration, retrieval utility retrieve not detected, not visible and inaccessible files lost due to deletion, format, corruption, Virus attack, damaged file system etc. Pen drive recovery utility can restore formatted memory stick JPG, JPEG, GIF, BMP digital photos pictures images MS Word, Excel Access, PowerPoint DOC, XLS, MDB, PPT office documents file retrieve MPEG, MOV, DAT, MP3, WAV, MIDI audio video music songs.
Removable media PEN DRIVE DATA RECOVERY SOFTWARE is Non-Destructive Read-only and safe easy tool to recover accidentally deleted files folders. USB external drive data recovery utility support windows XP 2003 2000 ME NT 98. Software provide support for multimedia card, compact flash memory card, SD card, removable micro drive, smart drive, media flash card memory etc. Thumb drive data recovery software provide recovery from 64MB,128MB, 256MB, 512MB, 1GB, 2GB, 4GB capacity.
Features:
* Pen drive memory stick data recovery software support windows XP, 2003, 2000, ME, NT, 98 and provides recovery from all capacities e.g. 64MB, 128MB, 256MB, 512MB, 1GB, 2GB, 4GB etc.
* Utility can restore DOC, XLS, MDB, PPT, MPEG, MOV, DAT, MP3, WAV, MIDI, JPG, JPEG, GIF, BMP files of digital pictures, photos, audio, video songs and office documents.
* Software restores the data even the message DRIVE NOT FORMATTED displayed. * Utility provide recovery form USB pen drive even data has been accidentally deleted or formatted.
* Provides files folders recovery from damaged, corrupted, virus infected pen drive.
*Support all type of USB drives and memory sticks including SanDisk AVB Kingmax Apacer Lexar PenDrive PQI Ridata Supermedia Super Flash Transcend Kingston Sony generic Corsair PNY Simple Ritek Crucial Dane-Elec Viking.
* Ensures recovery even if the removable media (pen drive) is not detected or inaccessible.
Post Number: 4256
sorry that last link didn't work for you It worked for me this morning I downloaded it to make sure it worked.
Username: Tulipe
Post Number: 183
DOREEN the site u gave me asking for money. i did do the download and the only thing you see is the demo . in order to have the software working need to pay them .
Post Number: 4295
Tulipe don't open the USB Flash Drive Data Recovery 7.0 20:02 .. Please check for a Malware. I just downloaded it and opened it and my Avira antuvirus told me it had to block the "setup EXE". Sorry for any inconvenience to you. Usually I check out files b4 posting the links here but I forgot.
I am going to try out another file and make sure this time all is OK with it b4 sending to you.
Since you seem to have trouble downloading files add my email address (PM me for it) to your MSN and I can send it to you through MSN and any other files you want. ( I WILL check them out for viruses first this time)
I am so sorry again for sending out Malware. FIRST TIME I have done that that I am aware of.}
Post Number: 4296
free trial
http://www.softpedia.com/progDownload/USB-Flash-Drive-Data-Recovery-Software-Download-135365.html
after you install this .. go into c drive ... program files.... folder USB drive data recovery.... copy/replace the crack into the folder
this is the crack to make it work fully without having to buy it. (virus free too)
Username: Lklives
Post Number: 16272
www.malwarebytes.com ...very good malware detector and fixer
Username: Nydas
Post Number: 18705
Plymouth has a good Malware detector.
Username: Tulipe
Post Number: 186
IM LOOKING NOT FOR MALWARE IM LOOKING FOR USB DATA RECOVERY.
doreen for some reasons i did what you asked me and when i open the application it always says error run time and desapear. each time i hit the recevery .
