Silver Member Username: JemoneTucker, Georgia United States Post Number: 333 Registered: Jan-06 | What is the name of the device that you wire between your battery and amplifiers that will present them with a constant 14 volts, even if the voltage is lower? It is not a capacitor. |
Silver Member Username: Gcs8Atlanta, Ga Post Number: 329 Registered: Sep-09 | a 1000 amp DC generator? |
Silver Member Username: JemoneTucker, Georgia United States Post Number: 334 Registered: Jan-06 | I do not think that is it. The device was produced by a car amplifier manufacturer at one point, and was, i believe, purple in color. You would wire the device like an amplifier, and even if your car experienced a voltage drop down to 10 volts, the device would send 14 volts to your amplifiers. |
Silver Member Username: Gcs8Atlanta, Ga Post Number: 331 Registered: Sep-09 | just sounds like one of thoes batt / cap combo thingies. |
Silver Member Username: Gcs8Atlanta, Ga Post Number: 332 Registered: Sep-09 | something like this ? http://www.sonicelectronix.com/item_13507_Power+Acoustik+CAPCELL-600.html |
Platinum Member Username: GlasswolfColumbia, SC USA Post Number: 12679 Registered: Dec-03 | it's a voltage regulator or line conditioner, but I haven't seen any for 12VDC use in a car. It still won't replace the need for an adequate alternator though, as it can't create energy. It can only convery current to voltage (provided there is enough current available to do so) or store energy in the form of a battery. Either way this is a needless gesture since you can do the same thing by just using an amplifier with a tightly regulated DC MOSFET switching power supply. |
Gold Member Username: SomedonniedudeIllinois Braaap MX Post Number: 2985 Registered: May-07 | "Either way this is a needless gesture since you can do the same thing by just using an amplifier with a tightly regulated DC MOSFET switching power supply." are you saying an amp with a regulated power supply (like a jl 1000/1)? or just an amplifier with a good/quality mosfet power supply? |
Silver Member Username: MmaudioconceptsKY USA Post Number: 701 Registered: Jan-07 | i think it was called the blade |
Platinum Member Username: GlasswolfColumbia, SC USA Post Number: 12684 Registered: Dec-03 | a tightly regulated power supply will draw more current to correct sagging voltage rails (if possible) and suppress the voltage f it's above spec, yes. That's what a regulated power supply does. The JL slash amplifiers have a regulated output as well, however, so they put the same power into any load between 1.5 and 4 ohms. http://www.glasswolf.net/papers/amplifiers.html see the bit about power supplies. |
Gold Member Username: Livin_loudMW2 Addict Post Number: 3085 Registered: Jan-06 | sounds kind of like a transformer... |
Gold Member Username: HdubbTeam Revolution Post Number: 4288 Registered: Nov-04 | flux capacitor |
Silver Member Username: Gcs8Atlanta, Ga Post Number: 334 Registered: Sep-09 | ^^^^^^^^^^^^^^^ |
Silver Member Username: JemoneTucker, Georgia United States Post Number: 335 Registered: Jan-06 | Thanks for all the answers guys. Leave it to GlassWolf to knock it out of the park again. My mind was stumped as to what it was. Oh...and by the way my current setup will kick all of your @ssses. I have a Olm2415 a bxi2008 and an unsound dampened trunk rattling so you know it is ghetto hittin'! Fear my bass Ha Ha Ha..LOL kidding. |
Platinum Member Username: GlasswolfColumbia, SC USA Post Number: 12691 Registered: Dec-03 | I have an AM radio with one dash speaker, and a kazoo. I'm wicked good with a kazoo.. you best come correct |
