Username: Jonez788 Post Number: 31 Registered: Jun-04
Monday, July 05, 2004 - 06:11 GMT Are there any 4 gauge kits with the fuse block all ready installed on the power cable?
Username: Davids2004 Houston,
TX
Post Number: 223 Registered: Jun-04
Monday, July 05, 2004 - 08:05 GMT No you ususally have to buy it seperate.
Username: Jonez788 Post Number: 32 Registered: Jun-04
Tuesday, July 06, 2004 - 01:04 GMT .....but almost all of the kits have the fuse block in them.
Username: Pat_l Tucson,
AZ
Post Number: 362 Registered: Apr-04
Tuesday, July 06, 2004 - 04:26 GMT Its, not hard to install the fuse holder. Just strip the wires
Username: Jonez788 Post Number: 33 Registered: Jun-04
Tuesday, July 06, 2004 - 21:33 GMT Well, I was helping my friend install his amp and the power cable didn't fit into the fuse block AT ALL. I don't know what was wrong.
Username: Jayj Louisiana
Post Number: 289 Registered: May-04
Tuesday, July 06, 2004 - 21:37 GMT What size wire are you using??
AZ
Post Number: 366 Registered: Apr-04
Tuesday, July 06, 2004 - 22:54 GMT All the fuse holders i have delt with i have had no problems like that. Mabey its a really cheap holder. You may need to upgrade to a better holder, its only gonna cost $10.
Username: Jonez788 Post Number: 34 Registered: Jun-04
Tuesday, July 06, 2004 - 23:38 GMT Well, I just ordered a knukoncept one. Glasswolf reccomended it to me. SO it'll be fine.
AZ
Post Number: 369 Registered: Apr-04
Wednesday, July 07, 2004 - 00:32 GMT Yes, Knukoncept is really good stuff.
Wednesday, July 07, 2004 - 00:42 GMT I've tried many times to try and contact Knu, but they never seem to respond to ANY of my emails (I tried emailing them from 3 different addresses with junk mail filter OFF). Any clue why they haven't responded back? (I want to order wires/kit/rcas from them)
