Bronze Member Username: Andy614
Post Number: 32 Registered: Feb-10
Posted on BASS INFERNO BIW12D4 Q-POWERS 600WATT (dont know what brand) QX1280-D4 and 12 inch MTX subs... theyre on craigslist and so i dont know which model.. |
Bronze Member Username: Gutteer
Post Number: 72 Registered: Feb-10
Posted on 1st one is junk and mtx kinda depends on the model but still not the best |
Silver Member Username: Jbpitt
Pittsburgh,
Pa.
Usa
Post Number: 277 Registered: Jul-09
Posted on I wouldnt waste my money on either one. If you post a budget im sure someone can recommend something alot better |
Post Number: 36 Registered: Feb-10
Posted on ha well my budget is up to $75.00 each |
Platinum Member Username: Glasswolf
Columbia,
SC
Post Number: 12650 Registered: Dec-03
Posted on save more money. better to spend a bit more for a quality amp, than buy some cheap piece of crap and regret it later. |
Post Number: 38 Registered: Feb-10
Posted on these are subwoofers... |
Post Number: 74 Registered: Feb-10
Posted on still both are pretty much junk so just leave them alone |
Platinum Member Username: Nyyfan13
Northern VA
Post Number: 11852 Registered: Jul-06
Posted on There is a very large difference between a $75 sub and say a $200 sub. With only $75 to spend on it, I'd take a look for a Alpine Type R on eBay. |
Post Number: 78 Registered: Feb-10
Posted on agreed type Rs are a good investment decent subs for the price and can pound if setup right |
