I want to get some 6.5" door speakers but dont want to spend over $150
Username: Trent6229
Alexandria, Louisiana United State...
I need a set of 6.5" door speakers and i dont wanna spend over $150. What are my best choices?
Username: Slo2sixty
Post Number: 15
Ive got low end polks in my car the 6.5s and they sound pretty good. If i could by another speaker i would save up and get a component set for sure. Mids are just soo much clearer with them, but mine arent amped yet so....
Username: 96camaro
Albany, Ny Usa
These are two great speakers, I'm going to create a post about which one is better. But for the money id try one of these two.
http://www.sonicelectronix.com/item_8368_Kicker+DS600.html
http://www.onlinecarstereo.com/CarAudio/p_17490_Audiobahn_AS65V.aspx
Username: Jwbulger79
Florida
Post Number: 533
i would hold off until you can afford an amp. you won't get that much improvement powering those $150 speakers with the head unit. An $80 set of components powered by a little 2 channel amp with 50 watts RMS per channel will sound infinitely better than any speakers powered by the head unit.
